Funny you should bring this up.
I spoke with Van less than 1 hour ago and we worked on fixing the front fender errors. Here is a copy of the fixes Van suggested. This wording will appear in the 2010 rulebook:
7.F MODIFIED PRODUCTION
7.F.4 Fenders:
7.F.4.1 Front Fenders:
A front fender is optional, and if used shall comply with the following: the front wheel and tire shall be visible from either side for a continuous 210 deg. of their circumference. The front of the fender shall not extend lower than 5 in. above a horizontal line drawn through the front axle. The perimeter of the fender shall not be farther than 1.750 in. from the tread. The sides of the fender may fair into the fork tubes, but shall not be over 2 in. wider overall than these parts.
7.F.4.2 Rear Fenders:
Rear fenders shall extend rearward to a point not less than a vertical line drawn through the rear axle. A seat that covers the rear wheel to the vertical line may substitute for the fender requirements. All fenders shall be of sufficient strength to resist deflection at speed.
7.G SPECIAL CONSTRUCTION
7.G.4 RESERVED
7.G.10 Open Class:
This class is limited to purpose built “bare bones” race bikes stripped of all aero and street use parts. No streamlining is permitted in the Open Special Construction class. Streamlining is defined as any device or objects that have the purpose of directing, limiting, or controlling airflow around the motorcycle or the rider.
The rear fender shall not extend beyond the back of the rear tire. If a seat/tail section is used, it must not extend more than 3 in. past the rear of the rear tire. No part of the tail section shall be lower than the top of the rear rim, or over 36 in. from the ground, with the rider seated on the bike.
7.G.11 Partial Streamlining:
If a streamlined seat/tail section is used, it can not extend further to the rear than 10 in. beyond the rear edge of the rear tire, or 1/3rd of the wheelbase and whichever is less. No part of the seat/tail section may be closer than 4 in. from the ground, or over 40 in. from the ground with the rider seated.
It shall be possible to see all of the rider: completely from either side, except the hands and forearms. As viewed from directly above it shall be possible to see all of the rider except the hands, forearms, legs and feet. It is forbidden to use any transparent material to avoid the application of these rules. Fairings or bodywork shall have a minimum of three (3) separate mounting points.
No part of the fairing ahead of the front axle may be lower than the top of the front rim at the axle vertical centerline or be forward of the front edge of the rim. There shall be no streamlining forward of the front edge of the front rim.
Front fender is optional, and if used shall comply with the following: front wheel and tire shall be visable from either side for a contiuous 180 deg. of their circumference. The front of the fender may not extend lower than a horizontal line drawn through the front axle. The permeter of the fender may not be further than 1.750 in. from the tire tread. The sides of the fender may fair in the fork tubes or sliders, but must not be over 2 in. wider overall than these parts.
