Author Topic: Front axle, spindles, hubs.  (Read 6406 times)
Offline robfrey
    • carbinitelsr
« on: November 22, 2009, 07:18:45 PM »
We are looking for a front end set-up for our liner.
No front brakes needed, of course.
Where do I look for this stuff? Chassis Shop has the spindles but no hubs to match.
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
Offline bbarn
Re: Front axle, spindles, hubs.
« Reply #1 on: November 22, 2009, 07:22:36 PM »
« Last Edit: November 22, 2009, 07:28:36 PM by bbarn »
Offline racergeo
« Reply #2 on: November 22, 2009, 07:27:37 PM »
   Rob, the spindles that the Chassis Shop sells are for TF and funnycar. Those hubs are built into the wheels. The funny car 15" are what I run and You can get Goodyears that are 21' tall to suit.
Offline robfrey
    • carbinitelsr
« Reply #3 on: November 22, 2009, 07:33:27 PM »
George,
what speed ate the goodyears rated to?
496 BGS
carbinitelsr.com
carbiniteracing.com
carbinite.com
« Reply #4 on: November 22, 2009, 10:44:22 PM »
not enough  :-D  you are going to need 16 Mickeys---I would suggest that you do ZERO scrub radius
Offline bbarn
« Reply #5 on: November 22, 2009, 11:15:19 PM »
How do you know it won't be enough? You didn't even ask how fast we were going to go. :wink:
On a totally unrelated note, what color is the 400 club hat? :-D
« Reply #6 on: November 22, 2009, 11:56:52 PM »
Hard to tell since it is made with invisible ink. LOL.
Offline maguromic
« Reply #7 on: November 23, 2009, 12:24:09 AM »
Build your own upright and use those spindles. It will give you more options and ways to go with the suspension.  They take an Anglia hub and are available from most race wheel manufacturers.  The Goodyear 21” LSR tires have been over 400.  Tony
« Reply #8 on: November 23, 2009, 12:58:45 AM »
  Front brakes would help a bunch if the chute fails.
Offline bbarn
« Reply #9 on: November 23, 2009, 01:07:27 PM »
I would assume these hubs will fit that spindle?
http://secure.chassisshop.com/partlist/6081/
Offline maguromic
« Reply #10 on: November 23, 2009, 02:05:11 PM »
Those are the spindles I am using on our rear engine roadster suspension.  We designed our own upright to sit inside the wheel.  The Anglia hubs work on that spindle.  Just be careful if you are buying used hubs and rims as they made some for Ford spindles as well. These are the solid models of our upright.  Tony
Offline racergeo
« Reply #11 on: November 24, 2009, 02:03:29 AM »
  Rob, the 21" Goodyears are just smaller version of the 24x16 Mickeys. Many streamliners use short steer wheels and just because Goodyear cautiously under rates them doesn't mean they won't go way faster. The 25x15 Goodyear LStire on the rear of NISH'S CAR HAS GONE 380 AND THE 21" TIRE IS A WAY BETTER DESIGN. It has a very short sidewall well suited to high speed. Also they are smooth tread like a LS tire should be. Keeps the front of the car low too.
« Reply #12 on: November 24, 2009, 10:34:22 AM »
one of those 380 15s went away  at around 360 one time ---dont know if it was published as to why ---led to a very fortunate ride.
Offline bbarn
« Reply #13 on: November 24, 2009, 10:40:13 AM »
I don't mind pushing the limits on some things, but what we are proposing is going to {hopefully} be well over the speed rating of the Goodyear's 300mph. I'd rather spend the extra cash on getting rated tires and making it home, especially a steer tire!
Offline interested bystander
« Reply #14 on: November 24, 2009, 10:47:06 AM »
Another appproach to spindles using the Chassis Shop "axles".
We built these for an 1100 lb Honda S2000 powered Altered class drag machine. It has rocker-arm IFS using mountan bike shocks. No brakes.
5 mph in pit area (clothed)
