McRat,
Anything can be done. You might want to look into a Turbo 400. Before planetary Lenco's there were Clutch Flights,(torqueflights with clutch) and Clutch Turbo's (turbo 400's with Clutch). A small adapter was used to run the front pump off the clutch. Pretty neat units, that gave you the launch of a stick, with the shifting of an automatic. Just had to remember to put the clutch in or put it in neutral when stopped.
My Roadster used to run a Turbo 350 without a converter. Would just push it up to 25mph and drop it into 1st gear. No problems at all. I also have a boat I built back in 1978 that I have a Turbo 400 in without a converter, behind a supercharged 454 Chevy, 30 years later it still works great.
