Thanks Brett. It's always a bonus when a manufacturer's rep enters into the fray in a constructive non-selling way.
Glad I can contribute Pete.
One more thing that I thought to add relative to earlier discussion on fuel cell height relative to pump mounting height. It is wise if the fuel pump is above the fuel cell to install a one-way check valve on the fuel pump outlet port. In so doing, once the system is primed, the check valve will eliminate drain-back when the engine is off, making restart much easier after a period of engine-off.
Also, initial start-up of a new fuel system with direct drive fuel pump should include manually priming the fuel rail. This can be done with a drive mandrel and spare pulley, along with an electric drill. We suggest going through the following steps:
1.) Crack the line at the fuel pump inlet and, if possible, gravity drain fuel to the pump inlet port. Light air pressure may be carefully applied to the fuel tank via the vent if the fuel line goes above the fuel tank en route to the fuel pump. Tighten the hose end once the pump-head is wet.
2.) Crack a line at the regulator, presumably mounted down-stream of the fuel rail, and run the fuel pump by hand or with an electric drill. Once fuel is at the regulator, snug that line and crack in sequence any remaining lines coming from other fuel rails on the engine following the same procedure.
3.) With all lines securely tight, crank the engine, ignition off, and verify oil and fuel pressure are present and their are no fuel leaks!
4.) Power the ignition system and light the engine, again inspecting for any sign of fuel leak.
5.) Raise the engine RPM to 2,000-2,500 and, with the vacuum line disconnected from the regulator, set the regulator for the desired, base fuel pressure.
Okay, last note: PLEASE BE CAREFUL WHEN HANDLING FUEL. Make certain their are no fuel leaks. Do not store fuel soaked rags in the shop, make certain the shop is well ventilated when handling fuel, obviously no smoking, sparks or open flames. Zero tolerance here guys and gals, the alternatives are NOT pretty.
Race safely and enjoy the sport!
Brett
