Neil, Skip, a trick on the Harbor Freight air hacksaw. As soon as you get it home, take the blade guide block apart, clean all the threads with brake cleaner or lacquer thinner, and then reassemble with loctite on the screws. It will last for years. Also, notch the plastic cover And aluminim case for access to the blade set screws and loctite the countersunk screw. I use bimetal blades for best results on fiberglass. I just snap off the length I want with a pair of pliers.
If you turn the teeth to pull, and run a little long on the blade, you can angle the saw to cut tight corners in your glass. You will be working farther out on the blade with this method. The blade can curve quite a bit! Stay a little off your line, then use the curved side of carpenters wood rasp to finish shape. The fine teeth of a wood rasp give very nice control on fiberglass, both flat or curved.
