Author Topic: V4 Dodge  (Read 238141 times)
Offline RichFox
Re: V4 Dodge
« Reply #195 on: February 09, 2012, 07:57:48 PM »
I couldn't tell from the photos where the cam was located (probably in the same place it has been for years).  Foolish of me to offer the suggestion.  I'm well aware that you know more about that engine (and all engines) than I.  Just thought I'd offer it up for discussion.
I welcome any and all sugestions. But in this case i have to much time in that cover to even think about a new one. We will find a place to put the fuel pump. It's funny that the Dodge is a shorter stroke engine than the Plymouth was. But has such a wide crankcase. I don't remember the Ply being this much trouble. But in a few years maybe I wont remember this either.
Re: V4 Dodge
« Reply #196 on: February 09, 2012, 10:59:56 PM »
lol  :cheers:  :cheers:
Offline 38flattie
Re: V4 Dodge
« Reply #197 on: February 10, 2012, 04:19:56 PM »
I'm with Anvil- if you can't run it off of the rear of the oil pump, the front looks good.
I'm not even sure you would need the plate and bearing setup-just hold the fuel pump pulley tight against the existing oil pump pulley.
I know you Rich- you're probably machining the parts to mount it, while we're reading this!
http://youtu.be/89rVb497_4c
Offline RichFox
Re: V4 Dodge
« Reply #198 on: February 10, 2012, 06:45:15 PM »
Putting the pully in front of the oil pump pully was the plan. Mounting the pump drive and it's pully off of the back of the oil pump was also the thought. But I forgot about how much room the hose takes up. Time to find a new place for the fuel pump. Plenty of shafts running around on this thing at both crank and cam speeds. We will see about it in the morning.
Offline zenndog
Re: V4 Dodge
« Reply #199 on: February 13, 2012, 07:36:54 PM »
Some pics.
Rich mounted the oil pump but the lower fitting was hitting the pan rail
So off it came to mill a new set of slots that would raise the pump slightly and allow the fitting to clear the rail. These are just a series of pics. For the most part I just tried to stay out of Rich's way.
Rich made some screws with points on them, we marked the plate on the car but then Rich wanted to make sure we had the right marks and them make them nice a deep
Center drill
Milling the slots
The first new slot milled, the pencil marks are where the others will be
Pump remounted
We looked at the fuel pump for a while. I think Rich decided where he wanted it but it was like a presidential election, what is the least bad choice. He wanted to think about it during the week and probably work without me looking over his shoulder. I imagine that if he gets it mounted he will post a pic.
Offline RichFox
Re: V4 Dodge
« Reply #200 on: February 16, 2012, 07:08:48 PM »
This is pretty much where the pumps go. Minus the Vice Grips and with a stand off to brace the pump. Higher than I wish they were. But they go where there is room.
Re: V4 Dodge
« Reply #201 on: February 16, 2012, 07:11:41 PM »
Looks good Rich, but don't the vice grips have better clamping power if you flip them around?! :-D
Offline 38flattie
Re: V4 Dodge
« Reply #202 on: February 16, 2012, 07:28:44 PM »
It works, and it looks good!
Re: V4 Dodge
« Reply #203 on: February 16, 2012, 08:02:27 PM »
I've always been a "worst case scenrio" kind of a guy, so to me, this makes sense - if the oil pump belt breaks, everything shuts down, if the fuel pump belt lets go, you've still got oiling.
Seems there's never a perfect solution, but this is a damned good one.   :cheers:
Any other clearance issues to deal with on the front?
See you at WOS.
Offline RichFox
Re: V4 Dodge
« Reply #204 on: February 16, 2012, 08:16:18 PM »
I'm thinking of going with a C clamp when it's done.
Offline RichFox
Re: V4 Dodge
« Reply #205 on: February 16, 2012, 08:19:37 PM »
See you at WOS.
This is about it for the front of the engine. I still may mount an altinator. But it will be further back.
Offline zenndog
Re: V4 Dodge
« Reply #206 on: February 16, 2012, 10:24:46 PM »
Looks good! Whats next?
Offline Captthundarr
  • In line
Re: V4 Dodge
« Reply #207 on: February 17, 2012, 09:34:59 AM »
Sorry I can resist, I like the BFH method. Making good progress fellas.
Offline RichFox
Re: V4 Dodge
« Reply #208 on: February 17, 2012, 10:28:38 AM »
I'm sending the C clamp out for chrome
Re: V4 Dodge
« Reply #209 on: February 17, 2012, 10:30:44 AM »
Trivalent or hexavalent? :-D
