May 25, 2013, 02:07:17 AM *
Pages: 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24   Go Down
Author Topic: V4 Dodge  (Read 31278 times)
RichFox
« Reply #135 on: December 21, 2011, 03:36:10 PM »
How soon they forget. Matrix Machine---V4F/BFS---201.700 with a turbo charged "T" block. Also Stewart Family and Creel turbo V4F lakester. These are two turbo charged Speciality bodied cars that come to mind.
SCTA/BNI timer 1983 to 2004,Semi Retired,.
« Reply #136 on: December 21, 2011, 04:07:26 PM »
The question was about the Vesco liner.
« Reply #137 on: December 21, 2011, 04:07:40 PM »
Okay - and thanks, Glen.  At least I wasn't too far off -- they do have a vintage motor for the car even if they didn't run it this year.  Maybe what I heard was discussion about them running it.
Merry Christmas to Carol and you, too.
« Reply #138 on: December 21, 2011, 04:35:40 PM »
We ran the V4 two years ago and the flywheel didn't seat right on the crank shaft flange and buggered it up pretty bad. We are looking into metal spray or welding to fix. Haven't pulled it out of the block yet.
Next year plans are still being talked about including a blown motor (roots) type. Also looking for sponsors for the Turbinator.
« Reply #139 on: December 21, 2011, 04:41:50 PM »
The Vescos entered a V4/GS in 2009.  The motor is based on the A-B-C blocks.
At SpeedWeek 2010, Joel Young from Phoenix set the V4F/BFS record at 201 with a T-based motor.  Only 194", too.
Member of the San Berdoo Roadsters – California's most-exclusive roadster club.
RichFox
« Reply #140 on: December 21, 2011, 05:08:22 PM »
The question was about a 'liner with a "T" block, turbocharged that ran over 200. See post just before SSS. At least the one I answered.
« Reply #141 on: December 21, 2011, 05:35:38 PM »
SSS, asked about the Vesco liner That's the one I replyed to.
turborick
Go as fast as we can with as little as we can
« Reply #142 on: December 21, 2011, 05:42:27 PM »
Rich it looks shorter than the one you brought out to Elmo a few years back. how long is it?
Rick Yacoucci
Nebulous Theorem III #788
http://www.bonnevillestreamliner.com
V4F STR 60
« Reply #143 on: December 21, 2011, 06:03:55 PM »
Supercharged not turbocharged, correct?  No turbos in V4F.
Montana Dodge Boys Fast Four Special
2009 V4F/STR 115.681
2009 V4F/GR 116.439
2009 V4F/FR 117.597
2010 V4F/BSTR 127.352
2012 V4F/BFMR 130.843
www.fastfourspecial.com
RichFox
« Reply #144 on: December 21, 2011, 06:11:17 PM »
No Turbos in Vintage bodies. Specialty construction ('Liners and Lakesters) are allowed turbos. I know it didn't seem that way a few years ago. Talk to Miler Mike and Roy Creel. Not me. Rick, the engine from bellhousing flange to injector pump pully is 31 or 32 inches. I cut some off the nose/motor mount to allow the use of a dampner. So I guess it's a little shorter than it was.
turborick
« Reply #145 on: December 21, 2011, 06:29:51 PM »
so it looks like it would fit in the liner......
Rick Yacoucci
Tman
« Reply #146 on: December 21, 2011, 06:50:42 PM »
I see the virtual wheels turning^^^^^^^^^^^^^^^ grin
www.compulsionrodandcustom.com
Hotrod, racing and performance parts
zenndog
« Reply #147 on: December 22, 2011, 12:32:50 AM »
I am amazed how much chatter has been going on around here.
I am kind of shocked you even brought this up Rich.
V4F STR 60
« Reply #148 on: December 22, 2011, 09:37:12 AM »
I had come up with a list based on the 1 & 2/ 3 & 4 bore spacing of the Dodge block
Zenndog,
Any interest in sharing your list?
Pedro
2009 V4F/GR 116.439
2009 V4F/FR 117.597
zenndog
« Reply #149 on: December 23, 2011, 09:14:59 PM »
Sure, Rich pointed out that due to the order of the valves, some of these choices would require a custom cam. According to Rich, Pontiac and Lincoln would not. Oldsmobile and Pontiac have aftermarket aluminum heads available.
These are only classic engines, I didn't look into modern engines. The info is harder to come by on the web it seems. I wasn't thinking about the fact that there is .150 of bore offset allowed, so many modern SOHC or DOHC heads would work.
For some reason I thought that DOHC were not allowed but now I cannot find any reference to that in the rules.
Also if you cut a SOHC or DOHC head to fit over the bores, then the cam (or cams) need to be modified also.
Rich isn''t really interested in another OHV heads for the Dodge but who knows?
Enough rambling, here is the list.
These are engines that have the same bore spacing as the 1 & 2/ 3 & 4 clyinders on the dodge, followed by displacements that have 4" bore
Ford FE, 332, 352 (4"), 359-391 (4.050")
Lincoln Y block, 341(3.937"), 368 ( 4")
Olds Rocket, 371 ( 4")
Olds, 350 (4.057"), 400 (4" )
Pontiac 301 (4")
Happy Holidays everyone!!!
Pages: 1 2 3 4 5 6 7 8 9 [10] 11 12 13 14 15 16 17 18 19 20 21 22 23 24   Go Up
Google visited last this page May 16, 2013, 06:13:15 AM
