Author Topic: How to paint plastic?  (Read 2337 times)
Offline donpearsall
    • http://soundappraisal.com
« on: July 28, 2009, 12:22:39 PM »
I bought a mini-ATV to use as a pit bike. However it is red and I want it to be yellow. It has plastics that are the greasy-feeling type, so I imagine painting them is a problem. Is there a primer I can use that will stick to it, then use my regular auto paint over it? I know whatever paint I use will have to be flexible. What do the auto shops use to paint the plastic parts of cars?
Offline thundersalt
Re: How to paint plastic?
« Reply #1 on: July 28, 2009, 01:50:28 PM »
Ask your paint supplier for plastic prep/cleaner. Scuff with a gray scuff pad. Add flex agent to your paint.
916 REMR
El Mirage 200 MPH Club
Offline aneed4spd67
    • thequadsquad
« Reply #2 on: September 21, 2009, 11:56:26 PM »
I have had good luck with a product called 'Bulldog" from the auto paint store, it promotes adhesion to plastic /urethane. Some pro painters say there is enough flex agents in modern paint that you do not need it, but I like the advertised "adhesion" of the bulldog
Offline Constant Kinetics
  • I'm not Crazy, I'm Invincible!
    • Constant Kinetics
« Reply #3 on: July 22, 2010, 09:52:50 AM »
Krylon fusion spray paint is formulated just for plastic and would make an inexpensive, easy to use primer. Available at most autoparts stores.
Wierd is good
