Author Topic: TREITS STREAMLINER  (Read 1822905 times)
Offline Bob Drury
« Reply #885 on: September 26, 2011, 07:52:45 PM »
  Keep in mind that on Marlo's car dual blower belts couple the transmission output shaft to the intermemiate shaft and vice versa to the front differential if they run the front engine only.  They can also drive the rear differential using this same intermemiate shaft.
  This may or may not dampen the "hit" at a gear change.
  The rear motor is a different story.
  It's transmission drives thru a belt coupler directly to the rear end and so lack's the possible benifits (?) of the blower belt coupling.
  The coupler allows the intermemiate shaft to drive the rear differential with or without a rear motor.
  This is a lot easier to understand if you have a blueprint in front of you like I do!   :-D
        Bob
Bob Drury
« Reply #886 on: September 26, 2011, 10:47:14 PM »
I would be interested in hearing opinions on how the Target 550 drive train is going to survive when the single engine Speed Demon has had documented difficulties.
How does one compare an apple to an orange............
but they are both fruit.
Two streamliners...........
that share nothing in common..........
except for the goal.........
to be the fastest........
Offline interested bystander
« Reply #887 on: September 26, 2011, 10:59:50 PM »
The Gilmer belt drive(S) trouble me on Hume's 'iner
Not having a "BLUEPRINT IN FRONT OF ME" I worry about cantilevred(sp?) loads on the drive drain. Others have experienced that problem in more lightly loaded applications where the belts got throwed off.
5 mph in pit area (clothed)
« Reply #888 on: September 26, 2011, 11:05:23 PM »
The belts worked just fine on the Turbinator.
« Reply #889 on: September 30, 2011, 08:06:12 PM »
Well it's still Friday on the Left Coast and our post is on Target550.com
Have a look at the idler for the blower belts and the nose of the rear wheel fairings.
http://www.target550.com/gallery/134_idler_rear_fairings/index.html
Offline Kiwi Paul
« Reply #890 on: October 01, 2011, 12:28:55 AM »
Nice Work, especially on the Aluminum section. Makes me even more hesitant to visit. Not worthy, see....
« Reply #891 on: October 02, 2011, 12:12:28 PM »
Kiwi, I overlooked some fotos of the aluminum, shaping. I'll add them to the next post.
« Reply #892 on: October 02, 2011, 04:01:15 PM »
Freud, which does Jim Hume use, tig or oxy/acetylene, to weld up the aluminum panels?
« Reply #893 on: October 02, 2011, 06:06:27 PM »
 Lost this first time. Stepping on Frued's reply, sorry.
 Hume uses Oxygen and possibly Hydrogen but at least Acetylene.
His welds are so consistent and smooth they look like decals.
Some of the Top Fuel/ Funny Car pro builders buy tanks from Hume.
He engraves grapes and vines on them if you' re at the drags and checking.
« Last Edit: October 02, 2011, 06:12:07 PM by interested bystander »
« Reply #894 on: October 02, 2011, 07:35:22 PM »
Thanks, I B.
Youse is correct.
« Last Edit: October 02, 2011, 07:37:58 PM by Freud »
« Reply #895 on: October 07, 2011, 06:28:35 PM »
No post today. Probably Saturday.
I'm at Barber's Motorsport Park in Alabama.
Great weather and a magnificent event featuring Ducati motorcycles.
« Reply #896 on: October 08, 2011, 08:15:21 AM »
Barber has an amazing collection of motorcycles, enjoy.
« Reply #897 on: October 08, 2011, 04:03:13 PM »
I ran across an old picture of Marlo at the strip riding a crazy twin engine motorcycle where he sat above the rear wheel............ask him about it.
Offline saltwheels262
  • LTA 7/2013
« Reply #898 on: October 08, 2011, 08:23:46 PM »
any chance you can post it?
franey
ohio -    - 185.076 w/#684
lta 8/14  - 169.xxx. w/sw2
'16 -- 0 runs ; 0 events
                            - franey  8/2007
« Reply #899 on: October 08, 2011, 08:30:47 PM »
franey
I would but it is in a crate of 2-300 magazines I went threough last week :oops: I need to get some stuff done instead of reading all those things again! But, don't fear, I go on a reading binge about once a month and will see it soon. All I can say is Marlo was nuts in his early years! :cheers:
