Author Topic: TREITS STREAMLINER  (Read 1822617 times)
0 Members and 7 Guests are viewing this topic.
« Reply #30 on: July 26, 2009, 11:24:09 AM »
The third interview will be posted Sunday evening.
« Reply #31 on: July 26, 2009, 08:18:50 PM »
In case u have just signed on and the site opened to this page, here are the three videos of the Jim Hume interview.
Hope you enjoy them.
Part 1:  http://www.youtube.com/watch?v=9sz1xfuBHPs
Part 2:  http://www.youtube.com/watch?v=U_iyYxrXuoQ
Part 3:  http://www.youtube.com/watch?v=vSmYKObDhbg
« Last Edit: July 26, 2009, 08:28:33 PM by Freud »
Offline Brian Westerdahl
« Reply #32 on: July 26, 2009, 08:47:42 PM »
Thanks Freud and also Jim GREAT STUFF
« Reply #33 on: August 14, 2009, 01:01:34 PM »
I'll post fotos this weekend.
Offline t russell
« Reply #34 on: August 16, 2009, 09:24:08 PM »
Thanks
terry
« Reply #35 on: August 16, 2009, 09:39:16 PM »
...and PM me Marlo's postal address so I can send him that shirt.... :-D
you're not doing anything improper with that shirt of mine that you're looking after are you???????
« Reply #36 on: August 16, 2009, 10:54:05 PM »
Everyone wanted to "see down under" when the girl wore it at the wet T-shirt contest.
I've cleaned it up with bleach so it looks almost new.
« Reply #37 on: September 15, 2009, 12:49:08 AM »
Hi Fellows!
I took a few days off but Hume and Jason haven't. I have done fotos most every week except Speedweek
so I can bring the diary back up to date with 4 or 5 new posts.
In order to shape the body support pieces that will form the transition from the vertical sides to the under body,
they used the original buck to make hammer forms over which they will shape the transition pieces. The lower
section is constantantly tapering toward the back, just as the panels above do. So, all of these forms are cut on an angle,
as well as the contour curve to the flat bottom panel. The angle lines on the wood show the difference that the taper
generates.
I'll post those pieces tonight and in the next post I'll show you the finished supports that are made over these forms.
Nice to be back and Thanks for your patience.
« Last Edit: September 15, 2009, 12:58:50 AM by Freud »
Offline Rchop
    • FRS Engineering
« Reply #38 on: September 15, 2009, 09:49:30 AM »
The interviews were interesting Freud, thanks for posting them.
www.frsengineering.com
#4836 A-PBF 750cc(complete)
#765 A/G 650cc
« Reply #39 on: September 15, 2009, 10:55:06 AM »
I need help in posting them. Now that my granddaughter is away to school, I'll have to dupe someone into
showing me how to prepare and post on uTube,
Offline racefanwfo
  • jenks worlds fastest pitbull
« Reply #40 on: September 15, 2009, 03:37:25 PM »
how long till the car will be run. is there a target date.
The speed that you wish to achieve is only limited by the depth of your wallet.
« Reply #41 on: September 18, 2009, 09:36:44 AM »
RACEFAN......
Listen to the tail end of the third video.
Offline hitz
« Reply #42 on: September 18, 2009, 07:56:46 PM »
Freud,
   A question for you and Mr. Hume. At what temperature is the new streamliner skin straight? Is there a way to make an aluminum body so it stays straight in a big temperature change?
  I can't even begin to compare my amateur tin work on my lakester to Mr. Humes but it really looked bad when the sun hit it at Bonneville in August. Come to think of it, my old 8A Luscombe wings didn't look too smooth on a 110 degree day in Redding either. I think I see why most of the streamliners are fiberglass now.
  The metal work and the substructure on the Treit liner are a piece of art! Kudos to Mr.Hume and his crew.
  My oldest son told me years ago, "done is good too, dad".
  I've had a ride in it now! Slow but a ride. :-D
  Harvey
« Reply #43 on: September 19, 2009, 11:00:51 PM »
Great question hitz.
The difference in most aluminum skins and this one is thickness. The entire skin is 0.085", considerably thicker than any airplane wing:to my knowledge.
If you go back thru this build diary and the original one, you will see how close the support ribs are. There is much more support than usual. But actually
I have no reason to make that statement. It has been neither 105F or -20F in Hume's shop. So at the shop temp, it looks excellent and I guess it's
something they won't do extensive testing on to answer your question. Some engineer will likely give an opinion. I've given you my uneducated one.
« Reply #44 on: September 19, 2009, 11:24:58 PM »
Harvey, you drove me to explore some ancient art and the affects heat and humidity have had on the Sistine Chapel.
Michelangelo soldiered on and finished a masterpiece and when completed he wrote a description of his work experience.
I quote him;
My beard turns up to heaven; my nape falls in,
Fixed on my spine: my breast-bone visibly
Grows like a harp: a rich embroidery
Bedews my face from brush-drops thick and thin.
My loins into my paunch like levers grind:
My buttock like a crupper bears my weight;
My feet unguided wander to and fro;
In front my skin grows loose and long; behind,
By bending it becomes more taut and strait;
Crosswise I strain me like a Syrian bow:
Whence false and quaint, I know,
Must be the fruit of squinting brain and eye;
Hume said he can agree with Michelangelo except that Michelangelo didn't have an acetylene torch, a Bridgeport Mill, a Miller welder
or an English Wheel to help him, so Hume said the technology has given him an advantage over the storied artist.
Therefore both will put their art on display for the public to judge......when it's done. The Chapel has had it's facelift after 500 years, so apparently it's
still an ongoing project. Hume has about 485 years to go to reach the same level.
I doubt many climbed the scaffold to inquire of Michelangelo, "when will you be done? and what will the heat an humidity do to this picture?"
I appreciate your dedication if you have read this in it's entirety.
« Last Edit: September 19, 2009, 11:29:56 PM by Freud »
