Author Topic: Thoughts on Chains for Low HP Bikes ?  (Read 13455 times)
Re: Thoughts on Chains for Low HP Bikes ?
« Reply #30 on: July 10, 2009, 07:42:13 AM »
Don, you can thin the sprockets in a lathe. Rears are easy, front is tougher, can be ground and measure carefully.
 If they are surface hardened you may break through so might be better to buy a front. Make sure you radius or bevel tips, just like the side you left.
Yes you can do that, but only try it with rear sprockets. Front sprockets can be a lot harder than rears and are more likley to shed teeth under load. When i used to work for a  Ducati shop we found that even using non genuine front sprockets could be a problem with shedding teeth
On your 500 i would run a decent DID, Tsubaki, EK or other quality "O" or "X" ring chain in a 520. It may cost a bit more at first but it will last a lot longer
And John Burk, belts and various size pulleys are a whole lot more expensive than chain and sprocket combinations, they are also a lot more sensitive to alignment
Gray
Offline shiphteey
« Reply #31 on: July 17, 2009, 10:49:32 AM »
Hey Milton, good talking to you again after Maxton.  I think for a 1.5 mile venue like Loring, while the non-oring chain may help you slightly, you'll pick up more doing other things....go faster, spend less!   :mrgreen:
Gemini Motorcycles
229.6 mph at Loring
201.957 mph 2-way average @ Bonneville;
203.85 @ the Maxton Mile
207.2 @ Maxton -- NAKED
200.2 mph @ TX Mile
195.6 mph on GPS @ the 9/10ths
9.4 @ 157 in the 1/4
Offline relaxedfit
« Reply #32 on: July 17, 2009, 04:24:27 PM »
[/quote]
my wife keeps spending faster so i can go less
Ken Presson
Having nothing to do in shutdown is our goal
« Reply #33 on: July 17, 2009, 06:40:29 PM »
Good one!
Offline MiltonP
« Reply #34 on: July 17, 2009, 11:01:35 PM »
Yep...won't be changinging it for now.  Only thing to do before Loring is get that stock rear sprocket back on and see how high rpm I can hit in 6th.  Then decide wether to go -1 again or take off some plastic and run modified.  That may be detremined more by budget than anything else though.
Offline racer x
  • Dark Horse Racing 10-B
« Reply #35 on: August 06, 2009, 10:55:57 AM »
Are clip type chain master link connectors allowed ? I only have about 25 hp to try to brake a 520 chain  :-P But I would hate to show up and find out that I need a rivet type master link.
Thanks
« Reply #36 on: August 06, 2009, 11:28:47 AM »
I think so, but you can use a dab of RTV to help it from getting popped off.
Offline relaxedfit
« Reply #37 on: August 06, 2009, 12:41:45 PM »
Eric,
Are you coming back down in september?
Ken Presson
Offline racer x
« Reply #38 on: August 06, 2009, 01:46:02 PM »
Yes ,I miss you all to much to stay away
Offline roadracer
  • TLN Motorsports/KWS/Brock's/DCW/Vortex/WWB
    • TLN Motorsports
« Reply #39 on: August 06, 2009, 02:25:47 PM »
The old roadracing trick is the RTV and a piece of safety wire around the link.  The s/w on my link made it through Maxton and Loring.  The chain goes away now.  It's non O ring and disposable.  Just my preferance.
2006 Kawasaki ZX-6rr (Worlds Fastest standing mile and 1.5 mile)
2008 Kawasaki ZX-10R (4 200 MPH Clubs)
2008 Kawasaki EX-250R (Multiple ECTA and LTA records)
131 Land Speed Records set since 2008
125 Land Speed Racing records (including 3 Worlds Fastest Speeds) set since 2008.
Offline racer x
« Reply #40 on: August 06, 2009, 05:40:35 PM »
I Got the non o ring chain and it came with a clip fastener, That is why I was asking . I would have to go find a rivet type master link some where else.and buy another chain tool .(I lent mine out)
Offline 55chevr
« Reply #41 on: August 09, 2009, 11:08:51 PM »
Spring clip master links are acceptable
« Reply #42 on: August 18, 2009, 01:28:23 AM »
Chains can corrode if they are taken off of a salty bike after lake racing and they are put directly in oil.  This does not seem possible from a chemistry standpoint but it happens.
I use a good Tsubaki non o-ring chain for racing and a DID x-ring chain for the street.  Why do I do this?  I can take the non o-ring chain off right after I race and soak it in lots of water.  This dissolves the salt.  Then I put the chain in the oven at low heat to dry it.  Then it goes into a bag with some oil.  I can get the salt out of a non-o-ring chain so this is why I use it.  My bike does not have much power, but I get years of life out of a chain by doing this.
It is rare for a master link clip to come loose, but it happens.  I have never heard of a riveted master link coming loose.
