Jim, nice clutch setup... Is that the one that does not use a flywheel, rather it uses a FLEXPLATE (automatic style) ? How does that HTB adjust? Shims ? I assume that the hyd. lines are 4 AN ?
I have a Tex Racing Super T 10 and would like to use a Quarter Master duel disk set up like yours (lighter than a traditional clutch, pressure plate and flywheel set up) I do not have a bellhousing either,,, I run automatics now,, am building the 53 Stude with the 4 speed, so all prts must be purchased,, nothing laying around here that I can use...
Thanks
Charles
