Author Topic: Questions on oil plug safety wire  (Read 2774 times)
Offline tekebird
« on: May 17, 2009, 10:59:02 PM »
just getting the bike ready for it and my first time.
Bike is equiped with flush mount oil fill (and Clutch Adjustment plugs)
really no way to safety wire these......
Am I right to assume they must be replaced
Offline MiltonP
Re: Questions on oil plug safety wire
« Reply #1 on: May 17, 2009, 11:34:29 PM »
I don't believe the rulebook specifies that the plugs must be done.  That said, I believe every bike I have looked at did have them done.  I expect one, or more, of the techs will have some input shortly.  The axle and axle nuts are specifically pointed out in the rules so be sure to get those done if they weren't already.
Offline 55chevr
« Reply #2 on: May 18, 2009, 12:04:39 AM »
The oil drain plug wire requirement was removed ... what year rule book do you have ?
Offline 55chevr
« Reply #3 on: May 18, 2009, 12:10:44 AM »
I suggest you get a 2009 rule book and follow it exactly. The most common reasons for not passing tech are axles not properly restrained, incorrect/no kill switch, no metal valve stems, no metal battery restraint, non conforming chain guards, helmets not 2000 Snell+... If you have any questions direct them to Todd Dross (Narider) the bike tech bossman.
Offline relaxedfit
« Reply #4 on: May 19, 2009, 12:52:35 PM »
Like anyother safety issue, if you can make it better, do it better, then do it.
Ken Presson
Having nothing to do in shutdown is our goal
Super Kaz
« Reply #5 on: June 05, 2009, 01:10:59 PM »
Not sure if this will work for You,but a little trick we did on my bike was to safety wire a band clamp around my oil filter 8-)!
You can use this method on lots of different parts{instead of drilling} if needed :cheers:!
