Jon if the ABB electric car with traction control breaks
the speed of sound with a prop attached, crossing the salt
flats, will it pull the remaining water off or push the remaining
water off?, and if the shock wave slows the earths rotation 1m/s, will the new "minumum" time be enforced, or will you accept whatever is still on
our watches?
Because the toad, I mead road record was set on a road, the salt and water record would not be the same. It would be like comparing tea and crunpets.One you have to chew before you swallow and both are an aacquired taste.
The water would be expressed in knots and stiches per day.
Not to worry about the movement of the eaeth because I have it on good authority it is flat anyway, except pavement that is built to drain water. That is some of the reason the water takes so long to run off.
The return run for the prop job, would that be the suck run and opposed to the blow that got it where it is at ?
Inquieing minds want to know, and some don't have any place to stick it
OBTW: The "QUOTE" deal works great.
Keep up the good work.
Does it work the same in other countries. Is it tilted or even upside down ?
