My thinking on this.. I agree with the idea that you should set minimum downforce to the targeted max speed, (how much down force you need to keep your rear tires hooked up and front end just down at max speed) with the wings at their most efficient (best angle of attack, smallest necessary cord, flaps at 0, maybe even hight change for front spoiler,
{ front spoiler genrates most -lift in ground effect, drag also, higher off the ground, less lift, less drag})
http://www.strangeholiday.com/oops/stuff/annurev.fluid.38.050304.092016.pdfSeems like changing angle of attack would increase drag, decrease efficiency, more than other choices, might lead to stall at some point. What is it.. 2/3rds lift comes from pressure differential lift (in cars the air under the wing) and 1/3rd from impact lift (the air over/ into the wing).?
Flaps on the other hand change the shape of the wing, basically given it a thicker cord, the flaps could start fully deployed and progressively lay down with speed. This could be controlled by computer, using wheel rotation (ABS sensors). And as you slowed down at the end of the run, you down force increases to help slow you down. Electronics aren't all bad, or I wouldn't be picking your brains from my computer right now.
I am _no expert_ but this is what has been on my mind. Learning as fast as I can.
Breck
