Author Topic: New B Fuel Streamliner  (Read 15314 times)
Re: New B Fuel Streamliner
« Reply #15 on: May 07, 2009, 01:25:54 PM »
Tim,
Streamliner looks great, how about a picture of the rear of the car. Could not help but see a Coupe, Tub, and Roadster in the background. What years are they?
Offline Dynoroom
« Reply #16 on: May 07, 2009, 01:28:40 PM »
Tim, I hope you don't mind but I'll post a few for you that I took a couple months back.
« Reply #17 on: May 07, 2009, 01:35:27 PM »
Mike,
Thanks, much appreciated.
« Reply #18 on: May 07, 2009, 01:38:48 PM »
  All right, SUSPENSION  :-D :cheers:
« Last Edit: May 07, 2009, 01:43:16 PM by jl222 »
Offline interested bystander
« Reply #19 on: May 10, 2009, 10:14:22 PM »
Boy, this project is surrounded with some TALENT!
And we've also  got Hanna/Creitz/Moore and, of course, Hume's masterpiece for Mr. Treit under way.
Good to see all these old dragrace tin fabricators returning to the sport's roots.
« Last Edit: May 10, 2009, 11:06:53 PM by interested bystander »
5 mph in pit area (clothed)
Offline Jonny Hotnuts
« Reply #20 on: May 11, 2009, 12:06:00 AM »
I do believe you will want the 45 degree bars on the front half to lean the other way.
jonny_hotnuts@hotmail.com
*Andres Segovia
Offline Model A coupe
« Reply #21 on: May 11, 2009, 12:45:56 AM »
Weed,whatever happened to the 40'ty Ford featured in DRM?
Offline racergeo
« Reply #22 on: May 11, 2009, 02:34:03 AM »
 Whats the story on the smooth tread Goodyears? Are they something new?
« Reply #23 on: May 11, 2009, 09:27:21 AM »
looks like some "Power Salt Shaving" on one set   :-D
Offline mkilger
« Reply #24 on: May 11, 2009, 12:34:15 PM »
   and that why Mel Swan is doing the  tanks in our roadster I know they will be right and very nice.
Offline The wonderful One
« Reply #25 on: May 11, 2009, 01:27:50 PM »
The replys. Johnny Hotnuts. Doubt it. / Modle A Coupe. Sold it to John Buttera. / Racergeo. The front is a standerd Goodyear. 21.5 tall and rated at 300 mph. TWO
« Reply #26 on: May 11, 2009, 02:46:04 PM »
Tim, AKA Weed,
Looking at your front end is the A frame that locates the front axle side to side allowed to rotate around the axle? Can't tell from the pictures in Mike's E mail but I assume that it does as otherwise the front 4 link and the A frame will be "at odds" with each other during axle movement.
Just "kibitzing" as usual. Very neat car.
« Reply #27 on: May 11, 2009, 06:50:20 PM »
Rex. The answer is yes. Both front and rear. The receivers have a bushing that is honed. The sliders are ground with .003 clearance. Both are drilled for lube with a zerk in the rear of the slider. TWO
« Reply #28 on: May 11, 2009, 06:57:22 PM »
The primary forces on the 45 degree bars are “pulling” and not “pushing” and unless you have so much engine torque that you feel you will be able to do wheelies (like top fuel) this is not the strongest arrangement.
Hitting a bump at speed with limited suspension travel can generate massive forces, especially with additional weight often added needed to get traction. A simple broken weld at any of these 45's in this configuration could result in a catastrophic structure failure.....unlike bars that are pushing.
I am not trying to tell you what to do, nor do I mean to speak disparaginly of your project but before you dismiss what I am saying I highly suggest you consider the outcome if I am correct.
Good luck to ya.
~JH
*Andres Segovia
« Reply #29 on: May 11, 2009, 09:14:36 PM »
 HotNutz -Assuming you're referring to the triangular links- they are only to locate the axles SIDE TO SIDE -see "SLIDER" in Tim's reply to Rex. Watts linkage would do the same but this is much better for packaging.
Similar to Pro Stock dragrace rear end locators.
The people bulding the car have INCREDIBLE amounts of savvy.
