Author Topic: streamliner tubing dimensions  (Read 3244 times)
Offline guttley782
    • http://www.angelicbulldog.org.uk
« on: April 27, 2009, 09:30:45 AM »
Can anyone please update me on the roll cage situation with regards to tube sizing? After BUB last year, rumour was the SCTA were looking to change the roll cage dimensions to come in line with the car sizes. Is that still a possibility or is it still 1 1/4" by 0.090"?
An eccentric Englishman building a motorcycle streamliner with the help of a few friends!
Re: streamliner tubing dimensions
« Reply #1 on: April 27, 2009, 11:47:15 AM »
Guttley, no change on the the roll bar dia, & the thickness.
« Reply #2 on: April 27, 2009, 11:58:31 PM »
But if you build it to car cage specs, you will always be legal... no matter what they decide and it won't weigh or cost that much more... Oh, and you might be safer...  :|
Offline 1212FBGS
    • http://www.motobody.com
« Reply #3 on: April 28, 2009, 01:51:41 AM »
i wouldnt build it with 1.250...
kent
Offline panic
    • My tech papers
« Reply #4 on: April 29, 2009, 12:19:02 PM »
Small increase in diameter = big change in stiffness with tiny weight penalty.
Offline Loose Goose-Terry#1
  • Terry
  • When in doubt, GAS IT!
« Reply #5 on: May 04, 2009, 01:37:27 AM »
 8-) Yes, go with the car specs and use the bigger tube. That's what I'm going to do. Just going to cut the rider compartment out and re-do it with bigger tubes.  :-D
Terry  :cheers:
« Reply #6 on: May 04, 2009, 12:33:48 PM »
Terry,  I think that is VERY wise   :cheers:
