Author Topic: Roll Cage Repair Help  (Read 3125 times)
Offline 32hotrod
« on: April 15, 2009, 08:18:01 AM »
Ok we made a mistake before the real welder arrived and cut something too short. Is there an acceptable to SCTA repair of a roll cage bar. Past expirence in off road We placed a sleeve of the same ID inside the bar to be repaired , welded it via some holes drilled in it and then added in the new repair piece and welded them together. Does anyone know if this is an acceptable repair?
Thanks for your help
Re: Roll Cage Repair Help
« Reply #1 on: April 15, 2009, 03:55:01 PM »
I am not in ANY OFFICIAL CAPACITY!!!!!  If I were going to do that I would sure document the whole process---maybe even some show and tell pieces---but that is one of the correct tubing repair procedures---sleeve under each splice weld, with rosette welds in the holes you are talking about ---have you cut all too short or just one?  Where is the tube?
Offline 32hotrod
« Reply #2 on: April 15, 2009, 04:16:02 PM »
Hi it is the rood hoop in an S&W cage
Offline floydjer
« Reply #3 on: April 17, 2009, 12:17:22 PM »
Tubing is cheap. Neck/spine injuries .........
Offline Joe Timney
    • Delaware Chassis Works
« Reply #4 on: April 17, 2009, 01:40:11 PM »
It depends on the location, call me at 302.378.3013 and I will be glad to help you. I do this for a living and always error on the side of safety.
Joe Timney
DCW
Joe Timney
Retired President of ECTA
www.delawarechassisworks.com
