May 22, 2013, 03:49:03 PM *
Pages: 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 ... 67   Go Down
Author Topic: INDIAN 741 Supercharged...See you in 2011  (Read 134711 times)
landsendlynda
Location: FOUR! Count 'em 4 miles from the salt!!! Life is Goood!
« Reply #90 on: May 28, 2009, 11:05:01 PM »
Well, shingles and shotguns  cry guess I don't get a shirt. I don't do security for BUB.... sucks to be me!
Was a great thought while it lasted!
Lynda
Volunteer roadblock at Land's End! Yes, you need your stinkin badge! I'm your Dream Keeper, I protect your dream on the asphalt so you can chase your dream on the salt!
Online Online
« Reply #91 on: May 28, 2009, 11:34:49 PM »
Lynda, no worries. You would be spectacular w/o a shirt.
Poll results to be announced soon.
Calkins
Justin Calkins
« Reply #92 on: May 28, 2009, 11:39:06 PM »
I'll be a judge... shocked
Justin Calkins - Iowa Falls, Iowa
octane
The INDIAN "Saltcracker" 650 A-VBF
« Reply #93 on: May 29, 2009, 06:38:05 AM »
LOL...seams I could make good money selling t-shirts at Speed Week.
Wish I could go there.
Octane 98,
     Nice choice for breathers, What style fire sleeve are you running on your gas lines in your BUB class?
   Rocky
   1957S/VG
Rocky;thanks for pointing out there might be a problem
with the original breathers. You were right.
As for fuel-line sleeving, I'm using this stuff:
"..TEMPROTECT SLEEVING
Braided high bulk glass-fibre sleeve, silicone coated. Coated with iron oxide silicone rubber
 which will even shed molten steel , aluminium and glass offering outstanding protection
 to hoses, tubes and cables in a variety of hostile environments.
Continuous operating temp. 500ºF (250ºC)
Max. short term exposure 3000ºF (1650ºC)
Flame resistance - Very good
Abrasion resistance - Very good
Flexibility - Outstanding
Water & Oil resistance - Outstanding.
ironwigwam
« Reply #94 on: May 29, 2009, 05:38:15 PM »
Octane,
  It looks like a good choice to me. I am using a similar product from 3M over here but I am applying a kevlar sleeve over it as well, to prevent any exploding engine fragments to cut thru?.
  Your'e welcome for the breather lookover, beleive me if I see spomething I am going to let you know so when you get here, so our  others will have an easier time of getting you down the course and in the pits.
   Rocky
    1957S/VG
Online Online
Only time and money prevent completion!
« Reply #95 on: June 01, 2009, 09:15:45 AM »
Lars,
I was looking at your intake manifold/plenum and was wondering how it seal into the inlet ports. I re-read your posts and it looks like the 'spigots" on the sides of the manifold are inserted into the barrel inlet ports when you assemble the engine. How does this seal? Is there some level of "give" to allow for heat expansion and vibrations?
I am not a big  bike "guy" but there are so many really neat bikes being built for the BUB, and ours is one of the neatest!, that I am going to plan a "business trip" to Salt Lake City the week of the BUB and probaby just happen to stop by. See you then.
octane
« Reply #96 on: June 01, 2009, 01:02:30 PM »
Lars,
I hope so
Yes; the 'spigots' are inserted into the intake ports/'necks'.
The seal I mentioned earlier ( page 4 I think) :
Here's another small improvement on this almost-seventy-year old engine.
Originally the notorious 'sealing'-rings between the cylinders and the in-take
is made of brass, which inevitably will  turn brittle and leak.
Don't really want that, particularly on a blown engine.
Indian Parts Europe has managed to have these
space-age-unobtainium thingies made:
..from some sort of nylon-like material that will not change properties
subjected to intense heat (and cooling and etc.).
You get them oversized and they are then machined down
to your specific (in this case ; home-made) intake,
for perfect fit.
As you can see it's  tapered  ( is that the correct term?)
and there's an 'opposite' 'taper' inside the bolt-thingies
that screws onto the outside thread on the intake-'neck'
Other people's experience with these intake-seal is that they really do
keep tight, even on my friends souped-up Chief.
This bike running alcohol should experience
less heat expansion etc., so I'm optimistic.
The part of the intake with the 'spigots'
will vibrate along with the engine,
and then there's a rubber-tube connection to
the second part of the intake which is mounted to the blower (bolted directly to the frame)
If the seals don't seal, this being blown and all, I'll take it from there.
I'd rather not, but may be forced to, use some silicone material
Thank you for your kind words.
Yes; please stop by and say hello!
See you.
« Last Edit: June 01, 2009, 01:09:31 PM by octane » Logged
willieworld
« Reply #97 on: June 01, 2009, 01:09:39 PM »
i have ran the same style manifolds on harleys and never had any trouble with them --i use a wrench that i made with a long handle --love your bike hope to see you and the bike at bonneville  willie buchta
willie-dpombatmir-buchta
Calkins
Justin Calkins
« Reply #98 on: June 01, 2009, 01:23:04 PM »
Seams like it would work like a big compression fitting.
Do you think the alky will mess with your inserts?
octane
« Reply #99 on: June 02, 2009, 06:22:16 AM »
Thanks Willie !
We'll see;  Testing seal, submerged in methanol
BTW: the sealing-"cones" are made of (click:) PEEK / Polyaryletheretherketone
« Last Edit: June 02, 2009, 08:27:29 AM by octane » Logged
octane
« Reply #100 on: June 08, 2009, 03:46:23 PM »
No sealing cones were harmed in this experiment.
PHEW!
Been kind'a busy today:
Finally picked up the tooth-belt / wheels:
Ratio is ..erh...semi-educated guesswork: 48:26
5000 engine rpm --> 9230 rpm at blower. (10000 is apparently the max. for the blower)
Filed down some of the head and cylinder-'fins'
to make it possible to remove / reinstall the silly-shaped intake
without having to actually remove one cylinder
It's now doable (just) moving it to the right and then up and away.
We made the intake 'inserts'
..that goes inside the two intake-halves.
...to be connected with a silicone/rubber hose.
Trail-fit of wheels/belt:
Ha ha ...that machine look wiiiiild !
Goodness, I love it!
SCTA/BNI timer 1983 to 2004,Semi Retired,.
« Reply #101 on: June 08, 2009, 04:35:51 PM »
As I said before, nice work. cheers
ironwigwam
« Reply #102 on: June 08, 2009, 05:45:38 PM »
Octane, Nice experiment with methanol and rings of peek
PJQ
South end, Land of Oz
« Reply #103 on: June 10, 2009, 12:31:06 AM »
Ahhhh, that's dead-sexy...
Regards,
PJQ
Velocity Science Laboratories
octane
« Reply #104 on: June 10, 2009, 05:16:50 AM »
Thanks guys !
Yeah Rocky; I test all things that I plan on using (or maybe will use)
to see how it stands up to methanol by submerging them for a couple of days:
ARALDIT two-pack epoxy glue it turns to a soft-ice like substance.
Two-pack metal-filler disintegrates slowly.
Silicone like PERMATEX and CASCO seams to be totally unaffected
The 'raw' tooth-belt wheels/discs Kenneth milled to suit the drive (and blower)
..so we made a "final" test-assembly
...to check if things lined up.
Then pulled the whole thing apart to do the last welding on the frame
and today I'll take it to the sandblaster.
Funny; folks ask me how's going with the bike
and I tell'em we're pretty close;
then they look at the present state (as of yesterday. Kenneth showing the frame):
...and they think I'm nuts.
Mmm; maybe so.
« Last Edit: June 10, 2009, 05:33:43 AM by octane » Logged
Pages: 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 ... 67   Go Up
Google visited last this page May 21, 2013, 02:29:06 PM
