May 21, 2013, 08:37:30 PM *
Pages: 1 ... 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 [48] 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67   Go Down
Author Topic: INDIAN 741 Supercharged...See you in 2011  (Read 134686 times)
« Reply #705 on: July 22, 2011, 06:43:54 AM »
 cheers
WORDS to build by!
"--virtually the entire success of a turbo/engine system lies in thermal managemant."
 Corky Bell   MAXIMUM BOOST
" I am a firm believer in the people. If given the truth, they can be depended upon to meet any national crisis. The great point is to bring them the real facts." A. Lincoln
agendadocumentary.com
octane
The INDIAN "Saltcracker" 650 A-VBF
« Reply #706 on: July 22, 2011, 07:53:38 AM »
Lars, You are the Prince of Denmark with the stoutness of that tune-up.
  Rocky
  1957S/VG
Let's just hope that the Prince of Denmark is not related to the Prince of Darkness (Lucas)!  Hope to see you at BUB.
He's a VERY distant cousin, so I don't worry about it
cheers
 cheers to you Sparky !
See ya'
octane
« Reply #707 on: July 22, 2011, 08:16:25 AM »
The start-up the other day was mostly to check all systems
before it goes on the dyno Monday morning.
The guy who runs it has the appropiate name "Speedy".
He knows his stuff. particularly old stuff; he runs a turbo-charged Norton.
One thing we checked was if the vacuum piston in the CV carb
actually did lift all the way up at WOT.
I would have been surprised if it didn't
what with the blower and all, but here's one nerdy video to show it: CLICK
( probably won't win me a most-seen-YouTube-video prize...ha ha
Took the heads off to check things.
basically it all good:
absolutely no trace of damage to the fine new copper gaskets...PHEW !
No damage to the piston tops.
One little problem:
...slight valve/head interference.
Fortunately the heads are made of marsmallowium.
AURGH ! You might recall that I DID check for clearance before
engine assembly.
The problem is that the diameter of the bolt-holes in the heads a quite considerably larger
than the diameter of the bolts , so the head can move about.
I really should have made some dowels ( is that the term ?) going
through the head / gasket / cylinder, to keep them in position.
Any way, I removed enough material so it won't happen again
There was a slight sign of bolt-lubrication 'sweating' around the bolt-holes
its way into between the gasket and the head/cylinder
so this time I painted the gaskets , both sides, with zinc paint
before assembly, as suggested by some good folks here.
This also gave me an oppotunity to position the gaskets perfecrly on the head
while the paint was wet. I let it dry for a while and the gaskets were thereby 'glued' to the heads.
I could then turn them around and position the heads on the cylinders
WITH the gaskets under them in the proper position.
Getting ready for the dyno-test.
Wish me luck
and have a brilliant weekend ya' all  !
« Last Edit: July 22, 2011, 08:37:04 AM by octane » Logged
octane
« Reply #708 on: July 26, 2011, 10:33:55 AM »
Dyno test result
WoooooooooooooooooHaaaaaaaaaaaaaaaaa!
Now that was interesting:
did all kinds of set-up, gas , gas/alcohol, pure alcohol,
ran it lowered boost; simply put a too-weak spring on the pop-up valve
so part of the gasses/boost leaked out...NOT the proper way...but heeey: rock'roll !
First surprise: the boost is beyond the wildest expectations: 1 bar / 14.5 psi plus.
Must have been running with a malfunctioning blower at Bonneville.
I could watch the intake-hose expanding like a fat man breathing when cranking up.
Something I did not experience at Bonneville last year.
Finally after a lot of fooling around da' little devil delivered close to 40 bph at the rear-wheel
running pure alcohol.
That of course is nothing by the standards of what most of you guys run,
but for a little 70 year old stone-age-technology flat-head that left the factory with probably
considerable less than 20 bph , it is a result beyond my wildest expectations.
Some interesting figures:
accelerating from 100 km/h to 150 km/h is done travelling just 180 meters
or from 62 mph to 93 mph is done travelling just 590 feet.
It didn't get too hot. Nothing broke. Nothing fell off.
Here's a video from when it still ran on gas making some 32 bph.
No Indians were harmed during this video-recording.
CLICK
Removed heads today: no damage whatsoever to the head-gaskets,
no pitting ( is that the word(?)) on top of piston...PHEW !
I think my gasket problems is a thing of the past.
Going back there tomorrow morning to fine-tune ignition and jetting.
« Last Edit: July 26, 2011, 10:51:00 AM by octane » Logged
gearheadeh
« Reply #709 on: July 26, 2011, 12:26:36 PM »
Nice videos, great work, looks like things are coming together for a fun time at B.ville this year!
I especially like this part: No Indians were harmed during this video-recording.
ironwigwam
« Reply #710 on: July 26, 2011, 03:13:19 PM »
It raises the bar to keep on track. Thanks Cool Bean lars. Is that Moen in the background?
MC 1314
« Reply #711 on: July 26, 2011, 04:47:28 PM »
Lars
Were any Danes harmed?
I still say you will do 130..mph not kph.
See ya in Pre-stage.
Bob
It's just a case of too soon old and too late smart. Will Penny
ol38y
When all else fails, gas it!
« Reply #712 on: July 26, 2011, 07:55:11 PM »
That's great to hear Lars...  cheers  See ya in Sept.  grin
Larry Cason
2010 BUB 1350 M-PG record
twinspeed
« Reply #713 on: July 26, 2011, 08:36:52 PM »
Nice topic Lars, and thanks for posting dyno results... Very interesting project you have, very interesting.
Fine-tuning probably yields few more horsepowers.
twinspeed
« Reply #714 on: July 27, 2011, 03:53:20 AM »
Forgot to ask, what were or are the RPM's in best power?
I saw only the speed... Do you know the exact RPM number or what is the estimation of these?
Absolutely fantastic idea that supercharged side valve Indian...
« Last Edit: July 27, 2011, 03:57:05 AM by twinspeed » Logged
« Reply #715 on: July 27, 2011, 06:51:13 AM »
No indians were harmed---lol  cheers
« Last Edit: July 28, 2011, 07:55:45 AM by SPARKY » Logged
WORDS to build by!
saltwheels262
LORING 9/12
« Reply #716 on: July 27, 2011, 05:31:01 PM »
it sounds good lars.
it's a good thing your 4 way flashers are working.
see ya when I see ya.
franey
max 10/07 - a/pf   d license
bub '08 - 153.697 a/pf   pump gas
bub '09 - 156.377 aps/pf  ran out of gear
lta  '10 - 158.208  2 much gear 2x
                probably it for that mill, as is.
ohio - (1) 185.076 w/#684
          (2) 182.xxx w/20+ mph winds
lta  9/12  -148mph  in 3rd gear w/new #262 ( couldn't
                pull the rear gear in 4 much less 5 )
ohio - (4)  -153.x~in 4th.(+4 @the rear & leaving 1k+
      rpm on the table)
« Reply #717 on: July 27, 2011, 08:00:17 PM »
Hi Lars.  This build shows a fellow with strong craftsmanship talent who is progressing to learn the tools and analytical skills of seasoned builders and racers.  The future looks good.
octane
« Reply #718 on: July 28, 2011, 04:25:20 PM »
Rocky: check your P.M.
Lars
LOL.....nope
Naaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaa...no way
Bob
Looking forward to see you Bob!
In my book, you as a volunteer working to make it all happen, makes you one of the heroes of Bonneville
See ya !
We got the RPM readings fixed yesterday and as I remember it, the best power is around 4500 RPM
Cheers Sparky !
« Last Edit: July 28, 2011, 04:32:48 PM by octane » Logged
octane
« Reply #719 on: July 28, 2011, 04:36:37 PM »
franey
See ya' Franey !
Pages: 1 ... 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 [48] 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67   Go Up
Google visited last this page Today at 06:12:48 PM
