panic
« Reply #525 on: October 03, 2010, 09:03:30 AM » |
Actually, you're right. Moderators: please remove all this debris, since it appears I'm talking to myself.
octane
Offline
The INDIAN "Saltcracker" 650 A-VBF
« Reply #526 on: October 03, 2010, 10:20:20 AM » |
"A designer knows he has achieved perfection not when there is nothing left to add but when there is nothing left to take away" Antoine de Saint-Exupery
octane
Offline
« Reply #527 on: October 03, 2010, 10:25:48 AM » |
Never knew that so much could be 'read' from the state of the plugs. Great to learn something new ! Thanks Larry I'll be back later with a better photo of the plug and use the link to try'and figure out the state of affairs in the engine Hi Lars, Did you check your valve springs for coil bind?  ? ...mmmmm: I'm afraid I don't even know what that means When you read your plugs, you should look all the way down looking at the porcelin and plug body, Do you have a plug reading light? Mike R.
Yes ...sort of; I have a magnifying glass with a build-in light, but it's still hard to get the light all the way down there. I guess you've just given me an excuse to buy a new tool .-)
« Last Edit: October 03, 2010, 10:28:07 AM by octane »
Queeziryder
Offline
Former funnybike racer now Salt crew
« Reply #528 on: October 03, 2010, 02:29:26 PM » |
Hi Lars, Did you check your valve springs for coil bind?  ? ...mmmmm: I'm afraid I don't even know what that means Hi Lars, "Coil Bind" The simplest way to think of it is as follows; When your valve is fully open, there should still be some distance between the coils of the valve spring, usually in the region of 0.3mm per coil plus an additional 0.3mm. Therefore if your spring has 6 coils, then you need 7 times 0.3mm (2.1mm) of free movement at full valve lift. HTH Neil
Old enough to know better, but too interested in speed to care
octane
Offline
« Reply #529 on: October 03, 2010, 05:07:35 PM » |
Hi Lars, Did you check your valve springs for coil bind?  ? When your valve is fully open, there should still be some distance between the coils of the valve spring, usually in the region of 0.3mm per coil plus an additional 0.3mm. Therefore if your spring has 6 coils, then you need 7 times 0.3mm (2.1mm) of free movement at full valve lift. HTH Neil Ahh ! I understand now. Thanks Neil ! I'll check.
octane
Offline
« Reply #530 on: October 03, 2010, 05:17:03 PM » |
Isn't it about time to delete your earlier posts?
( This is directed at 'panic' I assume. ) I may misunderstand this BUT if it's some sort of personal beef or pi**ing contest, please take it somewhere else .... like posting a PM to the person to witch it is directed. With all due respect; I really do NOT care for that kind of stuff here....AT ALL !In my view, a pi**ing contest produces nothing but ...pi**. I don't care for that. Please explain what's going on. I just don't get it. The best thing would probably be to PM me. Thank you !
« Last Edit: October 03, 2010, 05:49:02 PM by octane »
ironwigwam
Offline
« Reply #531 on: October 03, 2010, 05:42:47 PM » |
not a pi__ing contest, but look at all his other posts and he deletes them in a few days. Actually I have no business being here as I know nothing about Indians. I rest my case in the hands of experts who have no idea how an Indian operates.
« Last Edit: October 03, 2010, 05:46:42 PM by ironwigwam »
octane
Offline
« Reply #532 on: October 03, 2010, 05:52:08 PM » |
PLEASE PM me, Rocky my man !!! I have absolutely no effing clue what you're talking about ! Thank you.
ol38y
Offline
When all else fails, gas it!
« Reply #533 on: October 03, 2010, 06:25:13 PM » |
http://cranecams.com/?id=5&show=faqLars, heres a little write on valve springs by Crane Cams. Towards the bottom they reccomend .060 clearance from coil bind. It was reccomended to me to have .100 when I set up my motor. So as you can see, there are many schools of thought.
Larry Cason Bakersfield,CA It's a dry heat!
2010 BUB 1350 M-PG record 2012 Speedweek 1350 A-PG record 169.975
Nortonist 592
« Reply #534 on: October 03, 2010, 07:13:28 PM » |
Lars, I don't know Panic but I do know he is sensitive. If someone disagrees with him all his posts disappear. Don't worry about it. Its standard operating practice. 2011 SpeedWeek will be here before you know it so getting the head gaskets sorted is far more important! By the way, Ivan in Thisted wants to be your mechanic for next year!
Get off the stove Grandad. You're too old to be riding the range.
grumm441
« Reply #535 on: October 04, 2010, 09:41:05 PM » |
Lars Looking at those gaskets, they don't have a steel fire ring Are they available with one or can you only get that on a round gasket G
I build it, Goggles tries his hardest to break it
« Reply #536 on: October 05, 2010, 01:59:38 AM » |
Lars, I think Grumm found a big part of your problem.
Sometimes it is best to sneak up on a problem. On flatheads it is easy to raise and lower the compression ratio. I would stack three gaskets on each head, torque the heads down, run the bike, retorque the heads, and run it couple of more times. Then I would do the same thing with two gaskets. One of these combinations will lower the compression enough to give you decent gasket life and performance.
Sweden is close to Denmark and there are the land speed on ice races. A great place to troubleshoot the engine make sure the gaskets work OK.
panic
« Reply #537 on: October 05, 2010, 11:35:12 AM » |
That's not the reason, but why bother.
WhizzbangK.C.
Offline
Ed Bennett, Speed Team Doo Kansas City fab shop.
« Reply #538 on: October 05, 2010, 04:02:53 PM » |
I too am curious as to why you seem to do this a lot. You've got to admit, without knowing what your reasoning is, it seems that Wobbly has made a fair assumption. So please, enlighten us as to why you do this. I'm not trying to stir up anything here, I find your informative posts to be quite valuable and feel a loss when you delete them. I read almost all the posts on these threads, trying to learn as much as I possibly can to help improve my meager efforts. I look forward to the discussions concerning different takes on technical matters. Everyone knows that there is more than one way to approach a problem and in many cases more than one "correct" solution to a given situation. Having access to a broad spectrum of opinions with information to back them is a valuable tool, and allows us to filter through them with some research and arrive at a solution that works for us. Everyone here has seen you take a lot of time to post detailed information with quoted sources, making the effort to help others with your knowledge, and then go back and delete all that work a few days later. I'm sure that I'm no the only one that has been disappointed to go back to review some of your posts only to find them gone. The loss of this information is not a good thing. I understand not wanting to get into a p**sing match with someone who may have a different opinion on the net, but if that's what the issue is why don't you just not reply to those folks. Leave the information that you've made so much effort to post available to those of us who may find it of use. Seems to me it's more effort to go back and delete stuff than it would be to just not reply to folks who want to argue.
Ah, this is obviously some strange usage of the word 'safe' that I wasn't previously aware of. Douglas Adams
panic
« Reply #539 on: October 05, 2010, 05:53:39 PM » |
"Disagree" suggests that text that I remove is my opinion. "Vanilla is better than chocolate" is an opinion. Generally, anything other than fact, historical data, actual dimensions, laws of physics will say very clearly IME, AFAIK, or attribute the statement to the original author. My statements (widely made, and disagreed with half of the time) that high rod ratio cannot make the rod "dwell" (stop) at TDC, piston motion @ TDC and BDC are not symmetrical, piston motion B&A TDC are not symmetrical unless the pin is centered, and that 1/2 the stroke does not occur at 90° are not my opinion, and do not require validation. When some rocket scientist "explains" "what is widely acknowledged", or "it stands to reason that", and repeats what he read off some magazine cover, I don't bother to discuss it with him. People who post things like "increasing the compression ratio 10% increases power by 10%" are not susceptible to discussion, let alone correction.
In short, arguing with a head-strong amateur is wasting everyone's time: mine, because I don't care if he's right or not; his, because he's not going to listen; and yours, because you're waiting for the dust to settle. .
