May 21, 2013, 06:55:00 AM *
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 ... 67   Go Down
Author Topic: INDIAN 741 Supercharged...See you in 2011  (Read 134466 times)
ironwigwam
« Reply #330 on: July 04, 2010, 09:35:52 AM »
Wow, That Indian Parts Europe really produces a nice electronic ignition kit! So do we have sound?
octane
The INDIAN "Saltcracker" 650 A-VBF
« Reply #331 on: July 04, 2010, 11:40:46 AM »
...yes indeed. It's the very type that sat on one of  "Burt Munro's" bikes in the "Worlds Fastest Indian" movie.
One nifty feature is a tiny LED lamp on the trigger take-up ( the small square aluminum box)
that lights up at the point of ignition. Makes adjusting the timing so much easier.
Yep; the sound of me going "AAAAAUUURGH",
after I found a tiny crack in the oil-tank.
Will weld it up tonight and later seal the tank with a two-pack sealer, just to be safe.
Rocky: how's going with the liner Huh
Is the engine ready ?
« Last Edit: July 04, 2010, 11:44:48 AM by octane » Logged
ironwigwam
« Reply #332 on: July 04, 2010, 03:36:02 PM »
Lars,
   I got the new moly rings for engine, still need to sort out some extra Bonneville valve springs for the valves, the heads are being machined , I need to check with Ed, the machinist as his wife is in hospital at the same time. The Lakeview fellows are geared up to reproduce the factory Daytona heads I have with a smaller valve chamber as a billet head if I can create the drawing in 3-D CAD solid works.. Engine is apart and ready to check cam timing of 4 lobes as I suspect I have the front cam jumped one tooth advanced. I will be out of town working this week, but should be ready to start assembling when I return over the weekend. The liner engine will be ready, if something comes up I have a back up plan that will involne an engine size change for BUB.
   Rocky
grumm441
Location: Preston, Formally Australia's car theft capitol. Still a tidy town
HK 327
« Reply #333 on: July 05, 2010, 08:12:27 AM »
Rocky
you're not using moly rings with a blower are you
I build it, Goggles tries his hardest to break it
ironwigwam
« Reply #334 on: July 05, 2010, 09:13:08 AM »
Rocky
  No I am not but Why not?
octane
« Reply #335 on: July 09, 2010, 01:18:08 PM »
Hi !...I'm still here.
Busy fighting the demons that keep popping out of the machine.
It's like a crazy dance where you take one step forward and two steps back and one one step forward and two steps back .....etc.etc.etc.
Rocky ! Glad to hear you're making progress !
ironwigwam
« Reply #336 on: July 09, 2010, 06:50:16 PM »
Demons ? from the oil pump? Remember its a gravity feed and pressure return to the tank
octane
« Reply #337 on: July 11, 2010, 01:12:59 PM »
..nope ( not that I know of, anyway ).
Just a load of things that are acting up:
a starter that won't work, a carb that gives me grief, some other stuff...blahblah......the clock is ticking !
I'm working on it.
ironwigwam
« Reply #338 on: July 12, 2010, 04:19:58 PM »
I,m glad the clock is ticking cause that means I am still on the right side of the green grass and I am in  control.
   Ever notice how some guys work better under a little pressure?
   Rocky
grumm441
HK 327
« Reply #339 on: July 12, 2010, 08:20:00 PM »
Rocky
If you get any detonation the moly falls off
desperate
« Reply #340 on: July 13, 2010, 10:02:20 AM »
Lars, did you seal your tanks yet? Over the years I've tried several brands, but I recommend this one 200%, it's superb and sets like rock overnight, as do any leftovers in the can sad
I always do both my fuel tank and oil tank on eveything I make. Mask off any threads! It's called POR15 and is single pack, you can get it from Frost Products http://www.frost.co.uk/item_detail.asp?productID=8232&frostProductName=Fuel+Tank+Sealer+(US+Quart%2C+946ml)++&frostCat=&frostSubCat=&CatID=28&SubCatID=
Don't push me, I'm close to the edge.
octane
« Reply #341 on: July 13, 2010, 04:48:14 PM »
Thanks Chris for the tip !
I already bought a somewhat similar single-pack product for the fuel-tank , but haven't 'done' it yet.
Methanol will eat most things two-pack , but for the oil-tank I'm going for
a two-pack product , mostly because several friends has used it successfully ( forgot the brand name )
Ha ha , I guess you're right !!!
Now back to work....the clock is spinning
« Reply #342 on: July 13, 2010, 08:52:12 PM »
Lars, will your oil have some methanol contamination in it and it will eat away an oil tank liner that is not methanol resistant?  I just thought about this after reading your last post and I do not know if it is a problem.  Maybe an expert will know.
Constant Kinetics
I'm not Crazy, I'm Invincible!
« Reply #343 on: July 16, 2010, 11:33:30 PM »
Awesome bike, Lars. I hope your still bringing it out in 2011 when i get a chance to bring my project(s)
Wierd is good
octane
« Reply #344 on: July 21, 2010, 06:35:59 AM »
Wobbly !... I'm listening ! Have reconsidered the choice of sealer.
CK: thank you for your kind words.
Short update, as I'm busybusybusy. I can feel the dark clouds of time's-running-out decending on me.
The nifty little designer-starter I made ?...no good. Big mistake.
I have something up my sleeve in that department . More later.
The beautiful old SU carb: big mistake. Keeps giving me grief of all sorts and parts hard to come by.
Opted for a Keihin CV carb that is off a Harley.
HD used them extensively on several models, but folks tended to replace them with
big shiny bling-bling SS carbs and others, so there's plenty on the marked for very little money.
Got this one dirt cheap at the local HD repair/parts shop.
Looks brand new in- and outside
Great carb. It's a CV...good for blown application.
Easy to tune. Has a acceleration pump. Parts are readily available.
Just to be safe I got a rebuild kit and to tune it for my application
I installed a Dyno-Jet tune up kit. Comes with a variety of jets , a different vacuum piston spring and
other useful stuff.
LOADS of INDIAN riders use this carb and this modification, so all I had to do was
jet it "up" to 50/50 % gas/methanol
Fabbed a new intake manifold using my new-found alu welding semi-skills
...and fabbed a new carb-to-air-filter manifold.
Because I needed the space for the mounting bolts....
 ...I had to weld INside the tube,
which for this here still-wet-behind-his-ears "weldor" was quite challenging
...and had to cut a piece off a thin-walled pipe
...bore holes through the intake and attach the pipe-bit
to make provision for the air passing through the flange--into---carb---up to vent the area
over the vacuum piston.
NOT pretty, but it works
and taking into account that this is the 4th. real functional part I have ever fabbed in aluminum
I'm not too ashamed about it.
Later added a flange that attaches to the seat-"cowling", so keep thing from falling off.
This engine is looking ...erh....weird
« Last Edit: July 21, 2010, 06:46:00 AM by octane » Logged
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 ... 67   Go Up
Google visited last this page May 20, 2013, 07:57:17 AM
