Author Topic: Single Cylinder LSR Motorcycles  (Read 28749 times)
Offline Calkins
  • On Any Sunday
    • Facebook
Re: Single Cylinder LSR Motorcycles
« Reply #60 on: April 30, 2009, 11:22:18 AM »
There is already 101mm big bore kit for it, which makes around 674cc.  109mm would get me about 749cc, but I'm not sure I can go that big with the sleeve.
« Reply #61 on: April 30, 2009, 11:39:49 AM »
Realistically, why go to the trouble? If you really want to set records, consider an inline 4. Otherwise, do what pleases you. JMHO.
slopoke
« Reply #62 on: April 30, 2009, 01:47:17 PM »
« Last Edit: May 19, 2009, 07:48:04 AM by slopoke »
« Reply #63 on: April 30, 2009, 04:50:08 PM »
Justin,
Use what you have. Make it legal to run. Get your feet wet and have fun. Then if you decide you like this type of racing, you can step up.
Offline fredvance
  • FVANCE
    • Vance and Forstall Racing
« Reply #64 on: April 30, 2009, 06:12:10 PM »
+1 for what Tom said!!  Fred
Offline Stainless Two
  • newest member of the 199.9 club :)
    • MySpace Page
« Reply #65 on: May 11, 2009, 10:49:12 PM »
Enjoying yourself is never a waste of your time...can't wait to see you set your mind to it, and make a go of it!
Look at my new RED HAT!!!!
#278 1000CC APS-G 208.959MPH record
209.093 mph best time
pit bitch to #1000 Bockscar
Proud to be a Texan!  in San Antonio
Offline Calkins
  • On Any Sunday
    • Facebook
« Reply #66 on: May 11, 2009, 11:20:45 PM »
Thank you!
slopoke
« Reply #67 on: May 19, 2009, 07:46:02 AM »
« Reply #68 on: May 19, 2009, 11:02:37 PM »
My son is starting to race with a single cylinder Honda.  Parts are relatively inexpensive and you only need half as many as for a twin.  Great.  He can learn riding, gearing, tuning, such as pipe building, cams, etc with much less work.  Good fun for both of us.
A good approach to tuning is to work in stages.  First, work on the externals such as carbs, manifolds, timing and spark, and exhaust.  And how to ride the thing.  You learn a lot about a motor at this stage.
Next, work on breathing, such as a port job and bigger valves.  Maybe a cam.  Can you make the engine flow and produce adequate power near redline with these modifications, using the standard size, and compression ratio?  Many engines can't, and its time to look at other motors.  An engine that cannot breathe enough with standard displacement will only be worse with more cubes.
If your engine breathes good at high rpm, its time to look at the next stage, such as increasing displacement or compression, or both.  These last options can be expensive.
This method will save you $ and time.  I had to give up on several engines because of problems detected in the early stages.  The head geometry would not allow them to breathe or they would not hold together at high rpm.  I had minimal money invested and this allowed me to move on to better engines.
Good luck with your project.  Hope to see it on the salt.
Offline Calkins
  • On Any Sunday
    • Facebook
« Reply #69 on: May 19, 2009, 11:09:42 PM »
Thank you for the advise.  I am actually doing research on it right now.  Thanks!
