Originally posted by Mark:
I was not advocating a position, but trying to open minds and induce healthy debate as to whether a differently designed points constuct could reward things we value more.
I would really like to see the ECTA rethink the points system. I would like to see the ECTA define what they are trying to accomplish, what they are trying to reward, and then how best to fairly do it.
For example:
Are they trying to generate revenue by encouraging attendance at every meet and multiple class changes per meet?
Are they trying to reward the racers that continually show up, run reliably and continually improving?
Lets face it, the points race is given a more ?prestigious? award at the ECTA and up until this year you didn't even have to go to impound to collect your points. If I remember correctly, the point?s winner gets a trophy, their vehicle picture on the shirts for the following year, on the rulebook & on the web site and the others in the top 5 or 10 get a plaque. When you make a record you get a paper certificate. I think if you?re going to be given a more ?prestigious? award, you should be scrutinized at least as much as you are for a record if not more.
Limiting class jumping will help make it a little fairer but that's not all it's going to take.
Here?s some thoughts I?ve seen thrown around on the subject, maybe we can brainstorm a decent proposal:
- Minimum speeds for points only (alleviates the advantage of open classes)
- Getting points for running in base class only (will show/reward actual improvement not just the ability to find a ?soft record/minimum? to run on)
- Coming up with a way to award points based on a percentage to somehow tie in the CC/characteristics of the actual engine or class entered to the speed achieved to make it a little fairer for the little guy.
Deb
