saltfever
Guest
« Reply #165 on: June 11, 2010, 05:04:17 PM » |
Thanks, Tony. How come you changed your avitar?
maguromic
« Reply #166 on: June 11, 2010, 06:10:48 PM » |
I changed it again, I couldn't help myself.
saltfever
Guest
« Reply #167 on: June 11, 2010, 07:48:30 PM » |
I guess I'll have to add mine. Not as good as yours though.
maguromic
« Reply #168 on: June 11, 2010, 09:30:07 PM » |
Offline
« Reply #169 on: June 11, 2010, 11:45:34 PM » |
Tony---that thing is going to be so so SWEET  what all do you have up front that requires so many or big pipes that require that much off set
WORDS to build by! "--virtually the entire success of a turbo/engine system lies in thermal managemant." Corky Bell MAXIMUM BOOST
" I am a firm believer in the people. If given the truth, they can be depended upon to meet any national crisis. The great point is to bring them the real facts." A. Lincoln
agendadocumentary.com
maguromic
« Reply #170 on: June 12, 2010, 04:32:36 PM » |
Tony---that thing is going to be so so SWEET  what all do you have up front that requires so many or big pipes that require that much off set  Sparky, The tub is shifted about 2”. The engine water tank has two 2” lines and there is also the fuel tank and the intercooler tank along with the cool suit tank up front. Then add to that all the wiring running down that side. Good thing is everything will be in modules so servicing will be very easy. Tony
Online
« Reply #171 on: June 12, 2010, 08:05:28 PM » |
"...servicing will be very easy..." Yeah -- that's what they ALL say -- before. Then it comes down to servicing the car in the pit -- all of a sudden it isn't quite as easy.  Nice looking race car, though. I look forward to seeing it in person.
Jon E. Wennerberg a/k/a Seldom Seen Slim Skandia, Michigan (that's way up north) 2 Club member x2 Owner of landracing.com
Cajun Kid
Offline
Venable Rod's & Racing #805 Studebaker, #806 Ford
« Reply #172 on: June 12, 2010, 08:14:51 PM » |
I sure like those pictures ? What kind of software was used to create them...
We layout our cars with graph paper and a few pencils,,,,
Your way looks better.
Charles
ECTA Record Holder Maxton E/CBFALT, E/CBGALT, E/CGALT, E/CFALT, A/CGALT, C/CGALT, D/CGALT, C/CBGALT, B/CBGALT, C/CFALT OHIO B/CGALT, C/CGALT LTA Record Holder and 200 Club Member A/CBFALT, B/CBFALT, C/CBFALT, C/CFALT, C/CGALT, E/CGALT, E/CFALT Fastest Standing Mile at Ohio 196.833mph Fastest Standing Mile at Maxton 191.006mph Fastest Standing 1.5 Mile at Loring 205.939mph http://s261.photobucket.com/albums/ii43/cajunkid5690/Blog www.venablerodsandracing.comemail venableracing@gmail.com
maguromic
« Reply #173 on: June 12, 2010, 08:58:27 PM » |
"...servicing will be very easy..." Yeah -- that's what they ALL say -- before. Then it comes down to servicing the car in the pit -- all of a sudden it isn't quite as easy. If think it will be easy, it just might be. Kind of like Alice clicking her shoes together.  But I think you correct in your assumption. I have yet to work on an easy race car. I sure like those pictures ? What kind of software was used to create them... Charles
We use Solidworks for most of the work. We have several files that go back and forth with several of us adding to them. Three of the guys are working on cars at LeMans this weekend and have been gone all month. Tony
« Last Edit: June 12, 2010, 09:00:00 PM by maguromic »
rebelce
« Reply #174 on: June 13, 2010, 06:44:27 AM » |
"Kind of like Alice clicking her shoes together." Can't get any easier than that Tony.
theazoldcrow
« Reply #175 on: June 13, 2010, 09:53:40 PM » |
 "Ceptin it was Dorothy!
maguromic
« Reply #176 on: June 13, 2010, 10:05:15 PM » |
 "Ceptin it was Dorothy! It was don intentionally to show how impossible it is. Armond AKA Rebelce was the only one that caught on. Tony
maguromic
« Reply #177 on: June 13, 2010, 10:19:45 PM » |
Finished the first run on the under tray and rear diffuser. There are two tunnels plus the center short tunnel. It should make several hundred pounds of downforce at a pretty low drag penalty (probably 1/3 of the drag from the same downforce from a wing). Just in case we need more downforce the center is designed to add a double diffuser in the middle. When we CFD the car with a flat bottom several weeks ago we tried all sorts of different wing configurations. The best one it liked was our bat wing that Steve designed. It will be interesting to see how the new bottom will like the bat wing. Depending on what the CFD tells us it may see a few more strakes in the tunnels also. Tony  Bat Wing
gotzy
Offline
« Reply #178 on: June 15, 2010, 06:26:10 AM » |
Hi Tony,
I've been watching your thread and design process and it's simply amazing!! I can't wait to see you guys building the components and putting it together.
I'd be very interested to see some how to's along the way, us ameteurs need all the tips and inspiration we can get!
maguromic
« Reply #179 on: June 15, 2010, 06:34:13 PM » |
Steve, Thanks for the kind words. Currently we are machining all the suspension parts and I will post them as they become available. I also asked for some of the CFD screen shots for posting as well. Tony
