Author Topic: 750cc pushrod bike build  (Read 69822 times)
Offline Rchop
    • FRS Engineering
Re: 750cc pushrod bike build
« Reply #75 on: April 29, 2009, 09:48:10 AM »
what are those jap bike parts doin on that american motorcycle?.......
kent
As long as the youngsters buy the fast bikes, wad them up on the street and sell what's left on eBay...I'll keep buying the parts. I'm an equal opprotunity bike builder  :cheers:
(I think I learned that from you and Randy)
Thanks Bob, that regulator came with instructions LOL
www.frsengineering.com
#4836 A-PBF 750cc(complete)
#765 A/G 650cc
Offline octane
  • Nimbus 750 APS-VBF
« Reply #76 on: April 29, 2009, 02:11:18 PM »
We'll want the fuel shutoff to be able to be operated without removing your hands from the bars -- but only if you're running nitromethane.  Either electric or cable (thumb-actuated) is acceptable.  You can get the thumb type from Pingel.
Hi Slim; I checked Pingel's website , I may very well be a bit dim, but I can't find'em.
Could you possibly point me in the right direction.
Thanks.
Offline Rchop
    • FRS Engineering
« Reply #77 on: April 29, 2009, 03:27:55 PM »
#765 A/G 650cc
Offline octane
« Reply #78 on: April 30, 2009, 02:49:43 AM »
Thanks a lot!
Offline Rchop
    • FRS Engineering
« Reply #79 on: April 30, 2009, 07:42:04 PM »
Today I worked on the air intake box. I fabricated the 9 inch round backplate...for the third time :x. I cut the first two plates from some 18ga stainless steel I had and ended up with 2 oil can bottoms. You could pop them back and forth just like an old oil can. I got out a bucket of ice water and the torch and tried to shrink the metal, but no joy. Sheet metal work isn't my strong point, so I finally cut a new one out of some 16ga mild steel and it remained flat. Now I have to paint it...dang! The intake tubing is 2.5 inch aluminum tubing and I will have a bellmouth made for the front.
Now I just have to decide how deep I want the box and make a cover.
http://www.frsengineering.com/pp71.jpg
http://www.frsengineering.com/pp72.jpg
http://www.frsengineering.com/pp73.jpg
#765 A/G 650cc
Offline Rchop
    • FRS Engineering
« Reply #80 on: May 02, 2009, 10:20:39 PM »
The air box cover has been meticulously fabricated and finished using proven TLAR* engineering...
...What's that Honey? No I haven't seen your salad bowl...why do you ask? :roll:
* That Looks About Right
« Last Edit: May 02, 2009, 10:22:45 PM by Rchop »
#765 A/G 650cc
Offline Rchop
    • FRS Engineering
« Reply #81 on: June 22, 2009, 06:18:36 PM »
Things have finally gotten back to normal around here and it's been too hot to work outside, so I'm able to work on the bike again. The airbox show on the previous pictures was too high. I had to put my arm around the outside of the box to reach the controls.
I decided to rotate the box down 180 degrees and run the intake in through the cover instead of the back. I will weld the opening in the back closed...
http://www.frsengineering.com/pp78.JPG
I installed the intake tube in the cover with the outlet pointed away from the TB intake...
http://www.frsengineering.com/pp79.JPG
This ended up being a much simpler installation than the previous one...
http://www.frsengineering.com/pp77.JPG
This setup will be used only while I get a feel for the adjustments needed on the fuel injection system. Once I get the hang of that, I will install some different pistons and fit the turbo to the bike.
« Last Edit: June 23, 2009, 01:41:49 PM by Rchop »
#765 A/G 650cc
Offline Rchop
    • FRS Engineering
« Reply #82 on: August 01, 2009, 01:14:31 PM »
Airbox backplate is complete with IAT sensor and bung for the MAP sensor. Exhaust pipes are complete.
http://www.frsengineering.com/pp81.JPG
Top motor mount/coil mount is complete.
http://www.frsengineering.com/pp83.JPG
Instrument panel and data logger are mounted.
http://www.frsengineering.com/pp86.JPG
#765 A/G 650cc
Offline Rchop
    • FRS Engineering
« Reply #83 on: August 01, 2009, 01:18:09 PM »
I'm not sure how well this throttle cable routing will work. We will see when the bike hits the floor.
http://www.frsengineering.com/pp87.JPG
#765 A/G 650cc
Offline fredvance
  • FVANCE
    • Vance and Forstall Racing
« Reply #84 on: August 01, 2009, 02:45:54 PM »
Is that an EGT sensor in the top of the rear pipe? The bike is looking great.
  Fred
Offline Rchop
    • FRS Engineering
« Reply #85 on: August 01, 2009, 03:26:15 PM »
Fred
Thanks Fred, that's the factory (single wire)oxygen sensor in the stock location for the Buell fuel injection. I have another self heating O2 sensor at the Y in the pipes for the data logger.
#765 A/G 650cc
Offline Rchop
    • FRS Engineering
« Reply #86 on: August 01, 2009, 05:29:57 PM »
Did a little work to relocate the throttle assy guide hole on the clip-on and re-aligned the throttle cables in a much better direction...
http://www.frsengineering.com/pp89.JPG
#765 A/G 650cc
Offline Rchop
    • FRS Engineering
« Reply #87 on: August 05, 2009, 11:36:40 AM »
I decided not to use the Charlie Toy LSR fairing on this bike. That fairing  was very wide for my build and I didn't want to narrow it since I have a GSXR frame that I'm going to use it on...
http://www.frsengineering.com/pp92.JPG
#765 A/G 650cc
Offline Rchop
    • FRS Engineering
« Reply #88 on: August 05, 2009, 11:38:01 AM »
I talked with Kent at Airtech and we decided on an appropriate fairing. The S&S fairing is a much narrower LSR fairing and should present a smaller frontal area for the bike. I picked up the S&S this morning at my local shipping depot. It was as expected, another quality product from Airtech.
#765 A/G 650cc
Offline 55chevr
« Reply #89 on: August 05, 2009, 01:14:35 PM »
Like the fairing ... perfect for a V-Twin ... please post the mounting system you devise for it ... Joe
