Author Topic: 750cc pushrod bike build  (Read 69755 times)
Offline Rchop
    • FRS Engineering
Re: 750cc pushrod bike build
« Reply #210 on: July 22, 2010, 05:29:53 PM »
New turbo installation uses 3 inch exhaust pipe with V-band clamp on the end. Elbow can now be rotated if needed or a different end can be installed when front fairing is installed.
http://www.frsengineering.com/pp166.JPG
O2 sensor will be installed in open bung when support brackets are fabricated and pipe is thermal wrapped.
http://www.frsengineering.com/pp165.JPG
#4836 A-PBF 750cc(complete)
#765 A/G 650cc
Offline Rchop
    • FRS Engineering
« Reply #211 on: July 22, 2010, 05:47:32 PM »
New BOV is adjustable and boost pressure controlled.
http://www.frsengineering.com/pp167.JPG
#765 A/G 650cc
Offline willieworld
« Reply #212 on: July 22, 2010, 06:46:15 PM »
7.B.20.     2010 SCTA rulebook        all exhaust system outlets shall be directed away from rider, the rear tire and the course surface.        willie buchta
willie-dpombatmir-buchta
Offline Rchop
    • FRS Engineering
« Reply #213 on: July 29, 2010, 06:49:30 PM »
New turbo installation is complete with new support brackets installed. Bike was tested on the country road in front of the house and this one appears to work much better than the first setup. A large bug was appropriately sacrificed on the front of the turbo at high speed to insure a safe test!
http://www.frsengineering.com/pp168.JPG
http://www.frsengineering.com/pp169.JPG
#765 A/G 650cc
Offline Rchop
    • FRS Engineering
« Reply #214 on: September 04, 2010, 09:04:50 PM »
New dyno has been installed. I can finally get the EFI mapped properly for this bike. Should be ready for Maxton by the end of the month.
http://www.frsengineering.com/pp172.JPG
http://www.frsengineering.com/pp171.JPG
http://www.frsengineering.com/pp170.JPG
#765 A/G 650cc
Offline isiahstites
« Reply #215 on: September 04, 2010, 09:06:39 PM »
Nice job Randy!
Offline 55chevr
« Reply #216 on: September 04, 2010, 09:07:43 PM »
That was one fast install ... I like it ... Joe
Offline Rchop
    • FRS Engineering
« Reply #217 on: September 04, 2010, 09:13:40 PM »
Thanks guys, I made one pass on it just to see if everything worked mechanically. I still have to load the software on my laptop and calibrate it.
#765 A/G 650cc
Offline Rchop
    • FRS Engineering
« Reply #218 on: September 28, 2010, 10:11:08 AM »
Success in Maxton! 4 passes made Saturday and the old record was bumped 20mph to 129 + mph. I kept increasing fuel pressure and went faster. I was planning on increasing boost Sunday morning and working into the 130's but I sold the bike Saturday afternoon and it was on its way to NY!  Joe Daly's nephew bought the bike to learn to Land Speed race. It's a great platform to slowly increase in size and go faster as you learn.
The new dyno made it a whole lot easier. I did learn something about dyno tuning though; with the type of dyno I have you can't simulate the load experienced on the track for more than a few seconds. My first pass logged at over 14 to 1 AFR when I had tuned to the low 12s on the dyno. I slowly made adjustments with fuel pressure increases since the injector timing was maxed in the WOT high rpm range. This brought the AFR down to where I wanted it and incresed my power and speed. The perfect scenario would be to put the bike back on the dyno now, and log the difference from the track to the dyno runs. This would give me a differencial to tune to on this bike for future track runs. Thanks to Todd Dross for that information. I can't do it with the turbo 750 since it's been sold, but I will tune the new one richer in anticipation of the track differencial.
So...it is on to the next, faster bike build!
#765 A/G 650cc
Offline saltwheels262
  • LTA 7/2013
« Reply #219 on: September 28, 2010, 12:16:42 PM »
you sure don't have any problem selling lsr bikes.
good for you .
i've got 2 for sale---
  120c.i. kneedragger v twin
  222 hp zx12r
franey
ohio -    - 185.076 w/#684
lta 8/14  - 169.xxx. w/sw2
'16 -- 0 runs ; 0 events
                            - franey  8/2007
