Author Topic: 750cc pushrod bike build  (Read 69745 times)
Offline Rchop
    • FRS Engineering
Re: 750cc pushrod bike build
« Reply #105 on: September 02, 2009, 08:54:20 AM »
I would post a picture of my recent injury however Slim, OSHA or my insurance company might have an issue with it.. :-o
Glad to hear you will be OK Randy.. :cheers:
J
thanks John, hmmmmm....now that leaves alot to the imagination :-D
www.frsengineering.com
#4836 A-PBF 750cc(complete)
#765 A/G 650cc
« Reply #106 on: September 02, 2009, 10:09:35 AM »
John, send the photos and descriptions to me and I'll have Nancy make the judgement on whether the visual is worth putting on the site.
Offline Crosley
« Reply #107 on: September 02, 2009, 10:48:40 PM »
wholly sheeeet... stuff happens quickly.  Glad you were not hurt worse.
In my middle aged years , Something I wear near full time when I am in my shop is safety glasses...  not to mention that they are bi-focal safety glasses so I can see stuff close up.  :-D
Tony in AZ...
"If you find yourself in a ditch.... let up on the throttle"
Offline Rchop
    • FRS Engineering
« Reply #108 on: September 02, 2009, 10:50:57 PM »
Thanks Tony, I had a full face shield and gloves on. Next time I'll remember to wear some steel mesh sleeves too :-o
#765 A/G 650cc
Offline willieworld
« Reply #109 on: September 02, 2009, 11:15:24 PM »
http://www.landracing.com/forum/index.php/topic,5479.0.html                      willie buchta
willie-dpombatmir-buchta
Offline John Noonan
Offline Rchop
    • FRS Engineering
« Reply #111 on: September 13, 2009, 09:50:12 AM »
The fuel tank is mounted low and behind the front wheel. I am going to run unfaired first, so I have made a tank protector to mount in the front of the tank...
http://www.frsengineering.com/pp100.JPG
http://www.frsengineering.com/pp101.JPG
#765 A/G 650cc
Offline Rchop
    • FRS Engineering
« Reply #112 on: September 13, 2009, 10:24:38 AM »
The front, top motor mount has been fabricated. The fuel tank vent and tip-over valve go through the middle of the motor mount. The vent filter will be surrounded by the neck gussetts. This should put the vent in a good dead-air space...
http://www.frsengineering.com/pp102.JPG
http://www.frsengineering.com/pp103.JPG
#765 A/G 650cc
Offline Rchop
    • FRS Engineering
« Reply #113 on: September 13, 2009, 08:08:13 PM »
 I finished my primary chain cover. This covers the short chain that runs from the transmission to the jackshaft...
http://www.frsengineering.com/pp104.JPG
#765 A/G 650cc
Offline Geo
« Reply #114 on: September 13, 2009, 10:35:05 PM »
Looks fantastic.  I really enjoy the bike builds.  They are so different from the cars yet I still find some engineering I can steal... a... borrow.
The best thing....  No blood
Geo
Offline saltwheels262
  • LTA 7/2013
« Reply #115 on: September 14, 2009, 09:35:48 AM »
rchop,
build continues to look good. where did you
get tipover valve?
franey
ohio -    - 185.076 w/#684
lta 8/14  - 169.xxx. w/sw2
'16 -- 0 runs ; 0 events
                            - franey  8/2007
Offline Rchop
    • FRS Engineering
« Reply #116 on: September 14, 2009, 10:41:04 AM »
Thanks for the comments guys. If I remember right, the tip over valve was from Summitt. Look under external tip over valve.
#765 A/G 650cc
Offline Rchop
    • FRS Engineering
« Reply #117 on: September 15, 2009, 03:23:51 PM »
The ECTA rules for steering stop angle at Maxton are different than the SCTA rules at Bonneville. I decided to make a stop block that can be rotated to meet one or the other by just loosening and turning it 90 degrees...
#765 A/G 650cc
« Reply #118 on: September 15, 2009, 08:52:54 PM »
Nice idea, Randy.  On one of our bikes we've drilled and tapped the tabs that were the factory stops.  We inserted a screw and use locknuts to hold it at whatever location we desire - to get the required steering angle maximum.  I like you way -- lots less work, and although it has only two possible ways -- that's just enough.
Offline 55chevr
« Reply #119 on: September 15, 2009, 09:56:53 PM »
2 clearances ... one part ... no loose components to forget ... I like it
