floydjer,
If the turbo(s) are big enough they should be able to actually drive the crank blower and become a compount engine. You can find out by looking at the inlet and out let pressure of the crank blower. If the inlet is higher than the outlet, which can certainly happen, then the crank blower is actually a motor and is driving the engine crank.
Top Fuel headers: I have heard the number of 400-500 per cylinder for zoomies. This is why when a cylinder goes out the car starts to move toward the side that the cylinder is dead. It would be interesting to set one on some scales and wack the motor to see what the down force is, although it would not be as much as during a run when they have both fuel pumps running. I always thought they should take the fuel from the injection return line and split the flow amoung the headers and make them even better rockets.
