I sure wish someone could enlighten me about the open wheel effect. The more I think about it, the more questions I have.
I know the principal of fendered cars, where we try to block air flowing into the face of the tire near the ground (like the spats in front of all four tires on many high mpg cars), but I wonder if there is lift going on over the rear, upper radius of the rotating tire? Here's something confusing:
I watched a special on global warming research, where they were developing computer controlled sailing ships (without sails) that had to be able to control themselves in any wind. It seems there is a property of a rotating cylinder, wherein wind/air flow across it at an angle (regardless direction of rotation) increases pressure on the "back" side relative to pressure on the "front" (Bernoulis prinicipal...spelled that wrong
). They were able to power the ship with two vertical rotating tubes, spinning about 300 RPM, in very little wind. It was amazing to watch, and the ships could handle much wider range of windspeed without attention...but I digress....
So....does that have any relation at all to a tire rotating in fast moving air?
Here's another weird one:
When Dan and I were running the mod roadster (Bob Sights Jr. car now), we found it would plaster HARD salt deposits into the paint, just ahead of the rear wheels, about 45 degrees up from the axle line. The salt was so hard I had to soak it off with water after a run. Everywhere else, the salt wiped off easily. I was told that Indy cars have air diverting body work in front of the rear wheels because of "high pressure ahead of the top of the tire, against the body", but I don't know if that's the whole reason. I was told it can be the highest pressure area on the whole car (?!?)
Sooooo....are we dealing with high pressure ahead of the tire (and in what area), or lift upward and behind, or both?? Should we try to keep the open tires clear of the nose, to make the car run straighter?
I'd like to hear some ideas or entertaining guesses! thanks!!
Regards, JimL
