What type of information can you learn in a wind tunnel? This is a question that the majority people ask since a wind tunnel is not a place often visited by most people. I will post some data (okayed by customer) from a A2 Wind Tunnel in house study to illustrate what information can be learned from each run.
A run is a term used in the tunnel which is a single test run. Every time you make a change to the model you then do a run to measure the effect of the change. This consists of a tear of the balance where the weight of the model and balance are zeroed out so that when the air/fan is turned on, the balance is measuring the aerodynamic forces in 6-components: Drag, Lift (front & rear), Side Force (front & rear), pitching moment, yawing moment, and rolling moment. All of these forces are studied to analyze what is happening to the shape, whether it is a car, motorcycle, or cyclist.
Below is a sample test of a Camaro in the wind tunnel. I just want to show 3 simple configurations (baseline + 2 tape configurations) and explain what the results were for this particular car.
Camaro Configuration: I will be vague with the information of the cars configuration because the customer didn’t want too many details given about the car and set up. It is not a Landspeed car, but can be illustrative to what information you could learn in a wind tunnel and how it applies to any type of racing.
TEST CAR:
1997 Camaro SS:
-Larger rear spoiler
-Wide performance wheels
-Road Racing Series
