Author Topic: Roadster Measurments  (Read 11053 times)
Offline Woodstock
Re: Roadster Measurments
« Reply #15 on: January 28, 2009, 09:37:13 PM »
Most repop roadster bodies use a real body for the male plug to make the female mold that the body is madeout of.
The tolerances stated will allow for the mold and body shrinkage that takes place with spray up FRP.
The wider widths are probably from a body manufacturer trying to make more room for driver/ rider by building wider cross pieces which wouldn't be that hard to do for a plug using original sides.
My original steel body is so deep in storage or I would join in the tape offerings.
Offline lvsalt
    • http://www.dcwaterjet.com
« Reply #16 on: April 06, 2012, 11:42:45 PM »
Mike and everyone els thanks for the impute.  I needed them for a friend whom I  am helping with his modified roadster.  Russ sent me  the official SCTA measurements for the '27 Ford. Everything is + or - 1" except for single digit measurements that are + or - 1/2".
REFERENCE DATA FOR 1927 FORD MODEL T ROADSTER BODIES
SPECIFIC MEASUREMENT   REF_REC   Tolerance
   To SCTA
                                                       Rules Committee
TOTAL LENGTH                                       92.5
F/W WIDTH                                          31.25
F/W TO BACK OF DASH                             16.5
F/W TO BACK OF SEAT                             54.875
F/W TO RA CL                                         76
F/W WIDTH AT BODY SEAM                        31.5
F/W PROTRUSION AT SEAM - UPPER             2.375
F/W PROTRUSION AT SEAM - LOWER            1.375
WIDEST POINT OF BODY                           48.5
LOCATION OF WIDSET                              RDS+8
OVERALL HEIGHT                                      24.25
LOCATION OF HIGHEST    SEAT BACK
   &DASH
REAR BODY WIDTH                                    42.125
REAR BODY TO RA CL                               17
REAR FENDER WELL TO WELL AT CL             43.5
REAR BODY IN LEAN AT TRUNK SEAM             0.75
WIDTH OF COWL TOP                              38
WIDTH OF COWL BOTTOM                        35.5
WIDTH OF BODY AT FDS TOP                   38
WIDTH OF BODY AT FDS BOTTOM             35.75
WIDTH OF BODY AT RDS TOP                   46
WIDTH OF BODY AT RDS BOTTOM              41.5
FDS TO WINDSHIELD INTERSECT - TOP     1.25
FDS TO WINDSHIELD INTERSECT - BOTTOM   2.25
COWL TO FDS FOR REFERENCE MEASURE   1.5
ABBREVIATIONS
FDS  =  FRONT DOOR SEAM
RDS = REAR DOOR SEAM
DNM = DID NOT MEASURE
CL = CENTER LINE
RA = REAR AXLE
NA = NOT APPLICABLE TO THIS CLASS
INSIG = INSIGNIFICANT VARIANCE IN MEASUREMENT
Are these measurements still correct to be legal? or has there been any updates? just wondering.
Gary Cole     DCWATERJET Z
