Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Calendar
Login
Register
Landracing Forum
Tech Information
Technical Discussion
(Moderator:
Motorcycle Rear Brake Setup
« previous
next »
Pages: [
1
Go Down
Author
Topic: Motorcycle Rear Brake Setup (Read 4126 times)
55chevr
on:
January 24, 2009, 02:23:23 PM »
This year for Bonneville I wanted to reduce the rotating weight and drag from the front brake. So I took the the front caliper and rotor off the bike. It would be tough to load and unload a bike off a pickup bed without a front brake to grab. I decided to use the front master with a long hose back to the rear caliper. Worked out fine. I would prefer to use the rear master with the rear caliper for stopping on the course and still keep the front master option for loading. Is there a way to combine the front master and the rear master with a tee connection into the rear caliper? Do I need a check valve?
oz
Geordie Power.
Re: Motorcycle Rear Brake Setup
Reply #1 on:
January 24, 2009, 02:39:48 PM »
You could use a standard Tee from Goodridge or earls and fit a line lock on the run from the bars to stop the back feeding of the resevoir
http://www.compbrake.co.uk/brake_p4.htm
You could even use a thumb brake like the stunt riders use if you wanted to lose some bulk from the bars.
Just a thought.
Oz
bak189
Guest
Reply #2 on:
January 24, 2009, 04:49:45 PM »
For loading and unloading without a frt. brake....
..........put it in low gear and use engine comp. and the clutch lever.....................very simple.............
55chevr
Reply #3 on:
January 24, 2009, 05:37:16 PM »
Tried that but the clutch drags just a bit too much when loading ... Joe
krusty
Reply #4 on:
January 24, 2009, 06:59:36 PM »
Put a small shut-off valve in the front brake line before you tee the front and rear lines together. Once you've unloaded, close the valve. Check with your local oval track late model/sprint car supplier for the valve; they're commonly used in those environments. vic
55chevr
Reply #5 on:
January 24, 2009, 08:47:35 PM »
Vic ... found a valve in Speedway catalog that will do that .... thanks ... Joe
ol38y
When all else fails, gas it!
Reply #6 on:
January 24, 2009, 09:08:10 PM »
I could be wrong but, you're gonna need 2 valves aren't ya. One to isolate each master cylinder.
Hooking the rear brake to the front master cyl. seems much simpler. KISS theory
Just my 2c
Larry Cason
Bakersfield,CA It's a dry heat!
2010 BUB 1350 M-PG record
2012 Speedweek 1350 A-PG record 169.975
2014 El Mirage Dry Lake 1350 A-PG 172.651
1212FBGS
Reply #7 on:
January 24, 2009, 11:01:39 PM »
you cant have 2 m/cyl in line... when 1 m/c pressurizes it bleeds out the compensating port of the other m/c... you cant put in a 1 way check valve cuz it wont release pressure
kent
bak189
Guest
Reply #8 on:
January 24, 2009, 11:07:40 PM »
If your clutch drags to much for loading and unloading get a aftermarket Barnett clutch.....
.....very simple............................................................
1212FBGS
Reply #9 on:
January 25, 2009, 04:32:08 AM »
yep if all the release stuff checks out OK its usually warped plates.... i've been using Barnett stuff for a long time, good stuff, great people... get yourself some
Kent
oz
Geordie Power.
Reply #10 on:
January 25, 2009, 05:25:17 AM »
or mount two rear calipers its easy no tees no valves or use a late model cbr1000 it has two indepependant inputs if i remember rightly
saltwheels262
LTA 7/2013
Reply #11 on:
January 26, 2009, 10:11:18 AM »
two people are needed to load mine each time on to anything. i am always on left and
#2 on right. #2 operates rear brake pedal while pushing/stabilizing bike. have tried in gear with clutch; ezr w/ pedal operation.
franey
bub '07 - 140.293 a/pg 120" crate street mill
bub '10 - 158.100 sweetooth gear
lta 7/11 -163.389 7/17/11; 3 run avg.-162.450
ohio - - 185.076 w/#684
lta 8/14 - 169.xxx. w/sw2
'16 -- 0 runs ; 0 events
- franey 8/2007
Pages: [
1
Go Up
« previous
next »
Landracing Forum
Tech Information
(Moderator:
