May 24, 2013, 02:30:37 PM *
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14   Go Down
Author Topic: turbo motor build  (Read 24221 times)
1 fast evo 2
« Reply #180 on: July 12, 2009, 12:26:16 PM »
I think you will be much happier with your new turbo.
Good luck !
Is she gonna make it to the salt this year ?
Best wishes, I can't wait to see how it does on the dyno and the salt.
                                 Mike Reichen
E.C.T.A. 200 MPH club
221.4 mph at Maxton sept. 08
Jonny Hotnuts
« Reply #181 on: July 15, 2009, 10:50:20 PM »
Good luck !
                                 Mike Reichen
Mike, I must admit that this is zero hour and as long as everything went smoothly I would make SW.
Well......
I have been going snakes#%t the last few weeks with a "ticking" in the new motor. I ruled out valve train and cam chain so you can understand I was freaking out thinking it was a main or rod bearing going out.
Today after doing some research found it is likely the TB's being out of sync as the sound goes away as soon as the clutch is pushed.
Needless to say I can breathe and I can finish getting the motor in! As long as it doesnt break on the dyno we will be at SW.
jonny_hotnuts@hotmail.com
*Andres Segovia
whitehendrix
« Reply #182 on: July 26, 2009, 11:20:32 PM »
i just went on a post-reading marathon.
 alot of awesome stuff in thise thread. very nice work, very good info.. some stuff i had not heard of or considered before.
 i've got a little turbo gem in the making as well.. picked up some good info i'll use.
 nice work man!!
Jonny Hotnuts
« Reply #183 on: July 28, 2009, 11:10:49 AM »
 nice work man!!
Feel free to mail me with any questions. I have been going hotnuts trying to get the car ready so I have not been able to post new info....but the car is much further along!
Dyno this week!
*Andres Segovia
Jonny Hotnuts
« Reply #184 on: July 29, 2009, 09:11:21 PM »
Got back from the dyno today.....
Found a bunch of problems.....
Throttle cable too close to header.....melty...
water hose to the block had loose clamp....steamy
Batteries not holding charge well.
Vac line to the gate too close to the turbo....again melty.
Was able to make 2 pulls after some break in (as described elsewhere on this forum).
1st = 280 whp
2nd = 310 whp
and then.....
after the pull noticed some water flow out of the bov!!!!!
Turns out I have a leaking intercooler core!
Took it off after I got home and poured out about a gallon of water.....
Motor is not hurt (thankfully!).
New intercooler on the way.
My dyno guy is now an expert with the Microtech software (required some calls).
Hopefully next session we will have fewer probs and more into tuning.
Moral to this story is:
Better to find your problems before you hit the salt.
All things considered 310 isnt bad (about 12 psi....and only 16 more psi to go) and no holes in the case.
YET!
*Andres Segovia
fredvance
« Reply #185 on: July 29, 2009, 09:29:10 PM »
Thats about double what you had last year isn't it?
  Fred
Jonny Hotnuts
« Reply #186 on: July 29, 2009, 09:42:04 PM »
  Fred
Last years 1507 made 246 WHP (in bike) with race gas @ 800' and 70 degs. I estimate at Bonneville it was only making 2-210 car whp. I base my HP needs on the 246 HP @ 175 mph and this should give me some rope (and even better 'cause the car would of went faster if we werent making licensing runs!)
*Andres Segovia
bvillercr
« Reply #187 on: July 29, 2009, 10:03:01 PM »
we battled a bad inter cooler last year.  Your lucky you found out a little early.   How long will it take to receive your new one? huh
Jonny Hotnuts
« Reply #188 on: July 30, 2009, 09:51:30 PM »
I had a PT1000 NDA'ed so it should be here Fri-Sat. Lucky that the PT1K is a very common size for "tuners" and they had a few on the shelf. This unit is a much better fit for the engine size and what little space I have to put it in. I am a firm beliver that everything happens for a reason.....this is an expensive little chunk but if it means not blowing the motor its money well spent.
~jh
Made a new all steel throttle cable today.....lets see this one melt!!!
*Andres Segovia
Jonny Hotnuts
« Reply #189 on: August 01, 2009, 06:55:28 PM »
You  can see the new intercooler peaking out from under the electronics.
Way happier with the new unit....fits 110% better and wont have to worry about my flow becoming laminar though the core (bad). Also note the busa ECU says 11200 RPM....I flashed the ECU to 11200 from the OEM 10800 and took out 2 degrees and removed softcut.
A shot of the new dash.
Still needs a little work with wire management but that is for tomorrow.
Check out the billet gear position indicator on the top (reading N for neutral).
This unit is super cool and also provides negative output for each gear for gear based boost controllers or No2 setups. Even on my personal bike I still find myself trying to shift into 7th gear.....I know my pop would hit upshift at least a dozen times before the end of a run in the car!
3rd fire bottle Sunday
Dyno Monday
We leave Wed.
~JH
« Last Edit: August 01, 2009, 06:57:58 PM by Jonny Hotnuts » Logged
*Andres Segovia
Jonny Hotnuts
« Reply #190 on: August 04, 2009, 02:33:30 PM »
For all who followed this thread it has been a long journey for me to build my first motor.
I honestly feel I could do another in 1/2 the time for 1/2 the money but that is a road I had to learn.
Dyno results.....
438 whp and plenty to go.
*Andres Segovia
Geo
« Reply #191 on: August 04, 2009, 03:10:15 PM »
It has been an interesting engine build.
Good luck, be safe, go fast.
Geo
Andy Cooke
« Reply #192 on: August 04, 2009, 04:57:53 PM »
sounds like enough for you to need that cowl....
have a good one
Andy
fredvance
« Reply #193 on: August 04, 2009, 05:23:12 PM »
Way to go JH, see ya Friday
  Fred
Jonny Hotnuts
« Reply #194 on: August 04, 2009, 05:35:46 PM »
THanks Geo, AC and FV!
http://www.youtube.com/watch?v=c7Cn5K6fHiE
WATCH THE INTAKE TUBE!!!
 grin
*Andres Segovia
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 [13] 14   Go Up
Google visited last this page May 04, 2013, 11:46:28 AM
