One word of caution, although you see many cars at Bonneville running Goodyear Front Runners, the standard tire is not speed rated for weight. The LSR tires look exactly like, and carry the same wording on the sidewalls. Only the code is different. The LSR tire have a much thicker sidewall and are rated up to 300 mph @ a max load of 1700 lbs., and have a code part# D2028,2029,2031, or D22-4, depending on size. They cost about 3 1/2 times as much, but in the long run, safety is numero uno. Contact Goodyear Racing for info. Bob
