Hey, everyone:
I'm planning to run my '80 Pinto in C/CGALT. According to the rulebook, one of the following modifications must be made to run in the class:
1. The addition of a step pan;
2. The engine set back a maximum of 25% of the wheelbase;
3. A front-wheel-drive vehicle converted to rear-wheel drive; or
4. Covered headlights and grille as described in paragraph 4.
Okay, so say I want to do the last modification. According to paragraph 4, "Bumpers, grilles and front lights may be removed and the opening created may be filled or covered. The filled or covered area may be flush with the adjacent body; the basic shape and contour of the vehicle cannot be changed. Engine intake air may be ducted from these openings."
I guess I'm just confused about the use of the word "covered" in the fourth required modification. If I remove the front bumper, grille and headlights, do I have to cover the openings, and if so, how can I then use these covered openings as air ducts? (Obviously, I want air for the radiator, and I may want to duct air from the headlight openings back toward the air cleaner.)
I may just be making this way more complicated than I need to. I guess my basic question is, if I remove the front bumper, grille and headlights, is that enough modification to get me into CGALT?
Thanks--
Gary
