Author Topic: Class Rule-I know  (Read 4432 times)
Offline Mike
Class Rule-I know
« on: December 15, 2008, 08:34:08 AM »
I know, I should just get a rulebook but I'm only doing pencil to paper right now.
Can anyone tell me the defining difference between the Street roadster class and the Gas roadster class?
I'm guessing that it is some simple things like headlights, door handles, etc (drag inducing parts that distinguish a street vehicle)
Thanks guys
newbie
dwarner
Re: Class Rule-I know
« Reply #1 on: December 15, 2008, 10:55:37 AM »
Among other things your street roadster will have to have rear fenders. The fenders will have to be mounted in the stock location so this pretty much dials out channeling the body. The floor boards and trunk floor have to be above the frame. The hood can be stretched a max. of 3" in the blown classes. Driver must be seated in the OEM position, left or right of the drive shaft. No open louvers on the deck lid or other air ducts. Headers must be able to be capped off, no indivdual stacks, collector tubes must be used.
Any body else? Stan Back is a competitor in the class, he will have more to add I am sure.
« Reply #2 on: December 16, 2008, 12:50:24 PM »
You got most of it, Dan.  Plus you must have headlights, full radiator and less engine set-back (15% vs. 25%).  If you wanna be a contender, don't even think dual purpose unless you're in a engine class without much competition.
« Reply #3 on: December 16, 2008, 04:01:34 PM »
....  If you wanna be a contender, don't even think dual purpose unless you're in a engine class without much competition.
Stan, are you suggesting building one with a Hayabusa engine.... for H  :roll:  :cheers:
Offline John Noonan
« Reply #4 on: December 16, 2008, 04:57:54 PM »
Cool,
More cars to run against....
Offline wilcox garage
« Reply #5 on: December 17, 2008, 01:22:39 AM »
Here are a couple more to add to the list. All stock panels, including cowl, cowl eyebrow and windshied post mounting stanchions shall be retained. Step pans and streamlining are not allowed, but a cylindrical tank in front of the grill is.
« Last Edit: December 17, 2008, 01:29:00 AM by wilcox garage »
Mark Wilcox,
142 D/BSTR  record qualifier 2011 219.935
182 D/BGMMP record holder 2019 215.798
Offline Mike
« Reply #6 on: December 18, 2008, 08:53:38 AM »
Thanks for the replies guys.
Sounds like I will be running Gas as opposed to street. ( I dont have fenders )
Obviously the competition will be harder. But that's okay.
I appreciate all your help.
It sounds like my assumptions about the class being very competitive are correct.
I like a good challenge!
LittleLiner
« Reply #7 on: December 18, 2008, 10:59:15 AM »
Also a slight variation of body/year allowed..   you can run a 27 T in STR but not in Fuel/Gas Roadster.
Offline Mike
« Reply #8 on: December 19, 2008, 10:22:28 AM »
my '30 should be good.
Who knows. maybe it will end up taking a shot at a fuel class.
Damn you all. Giving me all these new ideas! LOL  :-D
« Reply #9 on: December 19, 2008, 10:31:49 AM »
Sounds like I will be running Gas as opposed to street. ( I dont have fenders )........
I wouldn't let fenders stop you from being in street if that is where you want to be as the cost for them in contrast to what you will be spending overall will be like buying a small drink compared to a medium one with your next meal.
From what I've seen the street classes right now are as competitive as anything out there.  By the way move from a medium drink to a large one and spend the $10 or so on a rule book right now if anyone has them.
Good luck,
Offline jimmy six
« Reply #10 on: December 19, 2008, 10:40:28 AM »
I'd go with C/FR...Next year it should be right at 300 at Bonneville and 260 at El Mirage.......... :-D
« Reply #11 on: December 19, 2008, 12:30:33 PM »
Then switch to C/BSTR -- the 17-year-old record at 244 seems soft, too.
Offline interested bystander
« Reply #12 on: December 21, 2008, 05:48:53 PM »
Easy for you to say, Stan!
5 mph in pit area (clothed)
