Thanks for the input everyone.
Sum I am taking the frontal area X the drag coefficient to determine the drag area. I thought this would be a way to come up with a number for each car that could be compared apples to apples. I will try to use your flow chart. Thank You. I don't know if you remember me. I was pitted a couple spots down from Hooley, brown primer roadster, we talked about it some.
interested bystander yes that info does help, sounds like I may have a chance, My car is a gas roadster with 706hp on the dyno. My best pass has been 206.8 but I feel with some more sorting out, air intake duct to the carb, small gear change to get the rpm up, bigger carb that it is capable of 210-212.
My engine is a wet sump so there is some power to be had by dry sumping it. How much? Opinions?
My engine is 412" and I am running a 950 cfm 4150, with the poor air we have to deal with would I be better of with more carb?
The Firebird could run in 3 classes, GC 235.850, GALT 238.883, FALT 235.607. I am thinking that FALT class may be the one. A little fuel in my engine will help the hp numbers.
I am also thinking of running a 9 inch in the bird as opposed to the quick change in the roadster if I think I can get the gear ratio were I want it.
Thanks for the input everyone. I am open to everyones opinion. Vince
