We were adding about 100 HP to a 140 HP motor, the compression seemed to be fading in #2 a little more than the others. Dropped 10 psi in the qualifier, another 10 in the record run. Turned up the juice, a little,
went 230.5 against the 228, dropped another 10 compression so I turned up the juice again to make up for the loss of compression and to try to get a 235....
at the 4 we had a little issue
and this happened. The piston looked like the others except for the marks when it went to the top. Figured out where the compression was going during the autopsy. Counter weight tagged the rod, it cut the case in two...
However I was on track for a really great run
Joe, you are on the money about pressures with N20, as I said earlier, you are always on the edge of disaster with N20, it just takes a little issue to burn one up, or maybe start a bend in a rod.
This one ran about 19 miles after the rod started bending before it quit... maybe those guys make pretty good rods
