ok, ok, i'll get a little serious... try not to make your chute tube smaller than 5" cuz it will get really really hard to get your arm in it and try not to make it longer than 26" cuz it gets hard to get to the bottom of it... that said start at the end of your new tube grab a handfull of riser and stuff it all the way to the bottom, pull your arm out and grab another handfull and stuff it all the way to the bottom stacking it on top of the previous handfull like your laying bricks, carefully filling all the voids but not bunching or wadding... repeat till your out of riser and your at the laundry... now you dont want to wad up the chute but pack it the same way as the risers, carefully but tightly filling the voids... now if your using a spring eject pilot install it straight and squair in the tube, alot of failes deployments are from the pilot jamming itself in the side of the tube....fold the flaps of the pilot over the back of the spring and under the retaining strap as it will help to expose the pilot flaps to the airstream upon ejection... your chute pack should fill the tube to the point that you will have to ask for help getting the strap over the loop to get the cable in.. if shes loose and sloppy your tube is too big... also keep in mind that your chute will pick up salt and moisture after a couple of days so she will swell up and not fit in the tube anymore. time to take it back to the hotel to get washed... theres lots of tricks people use like choking the risers with masking tape or rubberbands to make it hit softer, babypowder, and others but stay away from using a baseball bat... Oh I put a pillow case under my car seat so i have a bag to put my salty chute in as i am waiting for my recovery truck to arive... it realy helps to avoid riser tangles and salt in the car interior...
yours in sport
Kent Riches
