I decided to use a Morse cable to shift the bike ... Rear peg shifter side
Fork stop set up ... tab is welded to frame ... stops welded to aluminum plate that I will drill and tap to bottom fork tree. Bolt on the stainless plate to the tab which limits travel to 15 degrees. I can adjust it with a different plate or remove it to manuever the bike around the shop and load it.
Kaz, did u just blow your witness protection cover by posting?Would any of us recognize you if we saw u at the bar?FREUD
