Some of the problem is that the fuel continues to burn after the valve opens. Diesel burns slow. Running a bigger A/R on the turbine hsg is something I'm trying next. But no matter what, it takes big backpressure to make big boost numbers unless you compound chargers. As far as hotrod diesels go, I'm not pushing much boost, 45-60psi, but since it's a single charger, drive pressure is high.
