willie, got it ... Gussets and Braces.... X Bracing, Diagonal Bracing, Cross Bracing, Sill Bars, Pro Stock/Funny Car set up, Think we will be ok on the cage once we decide entry and exit (with my size) need some well thought our drivers door swing outs (or lower x or y bracing so I can slide in and roll out ..lol)
The Chassis and Suspension is the big project... Have not decided on type of front suspension...Several Ideas floating around, but nothing final..
Not sure how much caster adjustment can get with a trick coilover Mustang II, or Tubular A arm IFS set up will yield..or how bump steer may come to play. The dropped straight axle like the Vicky is another idea, but using parallel leafs, but not sure how low we can go that way and how adjustable it can be..??
Almost certain will use 4 link and coil overs in rear with Panard Bar and sway bar. (Vicky has Pete and Jakes long ladder bars, and Panhard set up with adj coilovers)
Well my brain hurts thinking of all the possible combinations...
Charles
