Author Topic: Amo-Steele Liner  (Read 59288 times)
Re: Amo-Steele Liner
« Reply #90 on: June 29, 2009, 05:10:50 PM »
Installed some bars for lateral restraint, with the SFI pad there is about an inch on each side
« Reply #91 on: June 29, 2009, 05:15:15 PM »
We had some tube left over so also made a secondary protection tube for the fuel line as it passes the bellhousing
Also installed some steel plate over the top to protect those lines
« Reply #92 on: June 29, 2009, 05:27:31 PM »
Johnboy milled out a couple of 1/4 inch steel wheel mounting plates for our Aluminum fronts.
Jon tried to call Lee Kennedy Sunday to get a reading on the rules for lugnuts when you use the plate.
Sure hope we don't have to make those later.....
« Reply #93 on: June 29, 2009, 08:20:52 PM »
How did u get Johnbouy home from CR long enough to do some machining?
Oh I know, he has a mill down there.
« Last Edit: September 15, 2009, 01:04:16 AM by Freud »
« Reply #94 on: June 29, 2009, 11:25:46 PM »
How did u get Johnbouy home for CR long enough to do some machining?
It is easy to get JB to do a little work.... just give him a lot of work...
Offline joea
« Reply #95 on: June 30, 2009, 12:16:34 AM »
John Gowetski, Bill Stainless Steele , Marty and Kevin Sutton. ....etal..(all the siblings)....the whole Mountain States
Automation gang........are TOP NOTCH PEOPLE.......NONE BETTER...........
« Reply #96 on: September 15, 2009, 01:13:34 AM »
They did make it to the salt and they did run.
Offline bvillercr
« Reply #97 on: September 15, 2009, 01:27:23 AM »
Nice looking liner. :cheers:
Offline Roadster943
« Reply #98 on: September 15, 2009, 01:53:47 AM »
 Freud those are fantastic pictures. Thanks
Land Speed Racing, The sheer joy of spending every dime you've got racing for nothing but glory. David Freiburger
« Reply #99 on: September 15, 2009, 11:05:09 AM »
Jon and Stainless before they started their adventure.
« Reply #100 on: September 15, 2009, 11:08:36 AM »
so are you now 2 Jacks racing!!!!!!! :evil:
Offline hotrod
    • Black Horse photo
« Reply #101 on: September 15, 2009, 11:36:23 AM »
Here are a few other shots.
Larry
« Last Edit: September 15, 2009, 11:38:20 AM by hotrod »
landracing
« Reply #102 on: April 18, 2010, 10:18:45 AM »
Been awhile since last posted on this thread.
We have been busy redo'ing some components of liner.
We started by changing the steering system - Went from a panard arm front steering to a rack and pinion.
Here is the old setup
landracing
« Reply #103 on: April 18, 2010, 10:20:30 AM »
here is the new setup showing the rack and pinion steering system that Stainless did.
I will show pictures of the new stainless water tank and how it interacts with new steering shaft tp rack and pinion pictures ill get today.
« Last Edit: April 18, 2010, 10:27:42 AM by landracing »
landracing
« Reply #104 on: April 18, 2010, 10:23:49 AM »
Work weekend... Another item we had to have made was a new gear set for the liner. There was a 1.5:1 ratio and just was to much gear for where we are at now, so we had a 2.0:1 gear set made. Here we are setting up for install back in the box.
