I have a fat bottom, and I've never had a problem with blow over... What? oh you said FLAT bottom... well that's different.
Really tho if you look at nature you see that Salmon, Tuna, Marlin...etc have rounded bottoms and are capable of very high speeds and are very stable. One would think that a round bottom would be the answer to stability. Then we look at different types of Rays, Sturgeon, Sharks... mostly these all come with a flat bottom, but also are capable of very high speeds plus I don't think I've ever seen a Flounder "Blow over". This could also be a question of the type of medium the vehicle is traveling through, the surface condition, or the distance between the vehicle underside and the surface. There could be a disruption in the boundary layer airflow on the cars underside that is actually "Bucking" the car into the air, or problems with the airflow over the sides, or "chines" of the body that could be a disruption. It could be any number of factors that only wind tunnel tests could reveal. Most people don't have large amounts of money to spend on wind tunnels so the next best thing would be to Take it out and see what happens... I thought that was what the sport was all about.. " Take it to the track, and see what happens". Inovate and test.
