First I want to say a really big "Way to Go" to the Buddfab guys, 150 mph with only 50 cc's is really an acheviement!!!
But the real reason for this topic is a result of reading the Buddfab web site and a comment they made regarding setting the 100 cc class record. They mentioned that they exceeded the Nebulous Theroem 4 record for the class by 10 mph. Doing a couple of quick number that would mean they if both bikes have the same Area x CD number then the Buddfab engine made 28% more power than the Costello engine. Of course they do not have the same Area x CD number and my guess is that the Nebulous 4 probably has a smaller frontal area, so if we assume that they have equal horse power then the Buddfab bike has a 28% smaller Area X CD number and if the Buddfab bike has, as I think it does, a larger frontal area then its CD is much smaller than the Nebulous Theroem 4 bike. These two bikes are trully great examples of two different aerodynamic design "schools". The Buddfab is a classic NACA derived shape ran a sufficinet ground clearance to allow air to flow beneath it without becoming turbulant and un attached, the Nebulous Theroem 4 is the "Costello" design school of a very small frontal area with a flat bottom running at a very small clearance with the ground.
I am not sure what the 100 cc engine was in the Nebulous Therom 4 when it set the record but I did watch it run 214 in August with a Honda 250 single and again doing some backward engineering and assuming that the 250 Honda was probably good for 45 hp then the 100 cc motor would probably be around 13-14 hps so maybe the answer is that their engine was not as powerfull as the Buddfab engine. I would certainly expect a Honda CRX100 two stroke to be able to put our 20-25 hps with out much problem.
Jack if you read this please "dilute" our ignorance regarding the power of your 100 cc engine if you have a good hp number. The reason I bring this all up is I am presently designing a small engine lakester and I am wondering if I should make it flat bottom, the Costello school of design, or round body with good ground clearance the "classic" design.
Your thoughts please.
