Author Topic: "Private" meet -- Top Speed shootout!  (Read 345372 times)
Re: "Private" meet -- Top Speed shootout!
« Reply #570 on: September 25, 2008, 10:40:25 AM »
Ack bike is running.  Bike is under way.
moving, tow released, wheels up
« Reply #571 on: September 25, 2008, 10:41:58 AM »
Bike is slowing down...at the ten and slowing.  Vehicle is stopped on the track.  Motor is off.
Offline John Noonan
  • Location: 6 X 200 club member: El Mirage 2 Club, Bonneville 2 Club, Australia 2 Club, Maxton, 2 Club, Mojave 2 Club, Bubs 201 Club
  • 301 200+ mph time slips. 252 mph on a dirtbike
« Reply #572 on: September 25, 2008, 10:50:59 AM »
And......?
 :-D
Offline BrentMalone
« Reply #573 on: September 25, 2008, 10:57:55 AM »
Hey is Andy Green Still out there?????????? :|
« Reply #574 on: September 25, 2008, 10:58:04 AM »
Good News travels slow...Bad News travels fast?
MAYBE
Offline Frank
« Reply #575 on: September 25, 2008, 11:00:35 AM »
MAYBE
I hope you're right.
The suspense is killing me.
Offline wolcottjl
« Reply #576 on: September 25, 2008, 11:03:18 AM »
Maybe Jon forgot to plug in the laptop last night and charge it up - or the broadband wireless had a melt down from overuse.  :)
Joel Wolcott
Moving to 2 wheels in 2010
« Reply #577 on: September 25, 2008, 11:04:19 AM »
Lets all call his cell fone.
McRat
« Reply #578 on: September 25, 2008, 11:05:27 AM »
.., bad luck (the engine hurt a piston, that's what started the chain of events that led to the coolant cap coming off.  No oil or fuel lines were damaged -- it wasn't either of those sources of fuel for a fire that led to the problems)...
We found the same thing retired us from SW, two broken pistons.  But indeed, it can cause a fuel leak.  Ours did.  It pushes the injector off it's seat, and the fuel blows out the hole at very high pressure and temperature.  We thought the #1 injector was to blame for the fuel leak until looked into engine and saw the damage.
Offline jimmy six
« Reply #579 on: September 25, 2008, 11:13:36 AM »
SSS.................... I can wait apparently John can't..
John Romero
« Reply #580 on: September 25, 2008, 11:17:21 AM »
The main ingredient in Evan's Coolant is the same that is in K-Y personal liquid.  Seriously.
Well thats just great. Now besides performance anxiety I have to worry about a flash fire as well  :-P
bak189
« Reply #581 on: September 25, 2008, 11:21:06 AM »
Larry C cell phone say,  ...Ack abort run......
everything O.K. going back for another go...........
McRat
« Reply #582 on: September 25, 2008, 11:22:00 AM »
Dunno, they went over 300mph before having a problem.  Perhaps you should slow down?  :-D
« Reply #583 on: September 25, 2008, 11:23:16 AM »
Leo Hess team is reassembling the bike -- a new output shaft was flown in last night and being installed this morning (per the CB just now).
Terry Kizer was putting the Wheeler motor together -- oil breather let about a quart of oil loose, which started a minor fire and hurt the bodywork.  The motor is all tight now -- Terry's pouring oil in as I watch.  Sam is bending an aluminum carpenter's square into a nice curve -- to use to reinforce the body where it's hurt.  By the way, the new front wheel on Sam's bike is strewing more salt into the wheel cavity than expected -- enough that it also gets thrown into the body.  Working on a fix to reduce that.
Wheeler hopes to run in three or so hours.  Poteet/Main is chasing an electrical gremlin, but planning on running later on today.  OSU is back -- their wi-fi is up and running, but I'm still using the wireless that we brought with us (just in case.  Remember, OSU guys are the ones that played golf out here using white balls on the white salt).  Anyway, OSU is going to put the fixed motor in the car today and run either later today or tomorrow morning.
Burkland is two hours from having the motors buttoned up and running.  Hope to get in runs today (note I said runs -- hope springs eternal).
And the Ack team isn't responding to radio calls, so nobody knows the latest from them.
« Reply #584 on: September 25, 2008, 11:24:58 AM »
FIM Charlie is on the radio reporting that Ack is leaving the track where it broke down -- and is heading back to the pits.  No story on what the problem is at this point.
We're going to "stand down" for an hour.
