Willie, I have measured, but her is the rub, the line through the king pin is "imaginary" of a "projected path" through it, through the wheel and then through the tire to the ground. So, with all that is "looks" like I an as close to zero scrub as I can see. If there is any margin of error the "line" is just inside the center of the contact patch of the tire (less than 1/2" from center).
If there is a more precise or scientific way to "measure" this I would sure do that as well,,,,
Either way I now have
1) Narrower wheels (down to 5" from 7")
2) Narrower Tires (down to 5" from 7.3)
3) Less (much less) Scrub
4) More Caster (now 8 1/4 was right at 2)
So I guess the real test will be less than two weeks away when we Run at Maxton,
All theory says that the 4 changes above should help the car run straighter at speed and "wander" less, maybe even tend to stay straighter after it hits the bumps...
Charles
