Author Topic: Turbo plenum  (Read 106313 times)
Offline maj
Re: Turbo plenum
« Reply #105 on: October 18, 2008, 06:03:51 PM »
Intercoolers make good strainers.... :-D
Offline Jonny Hotnuts
Re: Turbo plenum
« Reply #106 on: October 22, 2008, 06:36:05 PM »
I thought that a copper up pipe would look sweet and the pre made fittings should flow very well and have many degree and radius options to snake it anywhere it needs to go. I have plenty of pipe to do the entire system from the turbo, through the intercooler and into the plenum. * I wouldn’t necessarily recommend anyone else using copper from a cost factor, I had a few 12'X2-1/8" sections lying around and figured it should be put to use…If I had to buy this pipe today I would be looking somewhere else.
Once I get the motor in car I will sweat the fittings and polish the pipes up. The motor in the pic is one of our backups and will soon be getting broken down to get it ready for big HP…..it is a bit dirty and looks bad but is nice to do pre fitment of the turbo stuff.
jonny_hotnuts@hotmail.com
*Andres Segovia
Offline willieworld
Re: Turbo plenum
« Reply #107 on: October 22, 2008, 06:40:20 PM »
jonny   nice work --used what you had and it looks good too    willie buchta
willie-dpombatmir-buchta
Offline bald1
  • neald
Re: Turbo plenum
« Reply #108 on: October 22, 2008, 08:24:00 PM »
Looks great!  Now I have  to gp engine turn something.
neald
Offline John Noonan
Re: Turbo plenum
« Reply #109 on: October 23, 2008, 01:40:28 PM »
JH,
If you run the pistons we "spoke" about it will raise the head mouting holes up about .070"-.080" from stock, keep that in mind when planning for the Turbo build..
J
Super Kaz
Re: Turbo plenum
« Reply #110 on: October 29, 2008, 05:26:40 PM »
Is there a compressor map for this charger?
Running "too big" (is there such a thing?) a charger means you need watch out for compressor stall, "surging".  Just a few seconds worth can destroy the charger.  On the map, there is a surge line, and if you try to operate to the left of the line, you have big problem.  It's not subtle, you'll know it when it happens.  It usually rears it's ugly head just as the boost starts to climb.  You'll feel the vibration and the sound will change dramatically, you need to downshift ASAP.
As long as your racing RPM range is all to the right of the line, no problem you can't drive around.  But if you grab the next gear, and it surges as the RPM falls into the next gear, it will be hard to accelerate.
BOV's have uses, but peak boost control should be left to wastegates.  Sure it will work, but you will run higher turbo wheel RPM, and you are wasting HP.  Your drive pressure stays up and doesn't drop like a wastegate will.  BOV's can be used to kill surging on shifting, aka "turbo bark", but won't stop surging at WOT at the low end of your RPM, only a different turbo setup or shot of nitrous will fix it.
I've learned what I know about turbos through trial and error using 19 different turbos (heavy on the error), but then again, it's a large displacement diesel engine, not a DOHC race engine.  I'm never under 30psi, and I use big, mostly ungated chargers.  So take what I post with a grain of salt, this is the interwebbythingy after all.  :-D
I thought I was hard on shiznesel :-o:-o You need and 6.0 Part's? :wink:
Offline dieselgeek
Re: Turbo plenum
« Reply #111 on: October 30, 2008, 10:26:19 PM »
Mr Nuts:  what engine management will you be running on this setup?  your build progress and pics are very cool!
Re: Turbo plenum
« Reply #112 on: October 31, 2008, 10:42:17 PM »
I use the piggy back Bazzaz FI self mapping injection controller and will likely be using MegaSqurit for the secondary injectors.
Anyone have an idea on what size L to A intercooler I should use?
I see companies say "700 HP" or "1000 HP" but are these sizes based on cooling needs for normal ambient temps?
Because B-ville is already hot should I use an intercooler rated at a higher HP rating based on the already hot temps?
I am going to use a separate water tank with ice....no Co2 or dry ice.
*Andres Segovia
Offline panic
    • My tech papers
Re: Turbo plenum
« Reply #113 on: November 01, 2008, 10:45:28 AM »
That would be my guess: heat rejection ~ D1^4 ÷ D2^4 in absolute temp, so the difference between 100° F ambient (actual) and 70° F (design) is (460+100)^4 ÷ (460+70)^4, or 983 ÷ 789, or 1.246.
Assuming equal efficiency, you need +25% capacity for the higher temperature.
The reduced air density at Bonneville also reduces efficiency, I would guess in direct propotion to the altitude, so roughly 29.92 (sea level) ÷ 25.64 (4,214 elevation) = 1.167.
If true, the combined factors total about +45%.
Re: Turbo plenum
« Reply #114 on: November 01, 2008, 12:18:43 PM »
Topic Summary
Posted on: Today at 09:45:28 AMPosted by: panic
Insert Quote
Whatever you get paid.....its not enough!
THanks
-JH
*Andres Segovia
Offline 1212FBGS
    • http://www.motobody.com
Re: Turbo plenum
« Reply #115 on: November 01, 2008, 12:31:21 PM »
yep gonna have to agree with ya on this one nutz.... so panic, you easily come up with all kinds of wild but usefull formulas, cool... some kinda hurt my gord... but do you actually use a slide rule for your day job?... i took a wild azz guess and got lucky on this one i put 2 1000hp intercoolers on my liner... kinda right in line with panics formula  :-D
kent
Re: Turbo plenum
« Reply #116 on: November 01, 2008, 12:40:01 PM »
Is there a problem with going well overkill for the cooler.
For instance, lets say I use one that is rated at 2K HP....my real HP will never be over 650.
Because the intercooler is being fed from a water tank with ice is there any issues with running a cooler this much bigger (meaning the ice tank wont over cool the intake charge, even at 100% efficiency it wont cool more than the water in the tank).
just wondering if I should target a cooler in the 1000 HP range or is it ok to run one bigger than needed (looking for the future).
*Andres Segovia
Re: Turbo plenum
« Reply #117 on: November 01, 2008, 12:46:36 PM »
Not an expert!! :-D!!!  I would think your trade off might be some additional pressure drop (Maybe) but you should gain by having additional btu cooling reserve from the additionl mass that has been precooled. :-P how you feed the cooling water will be important.
Re: Turbo plenum
« Reply #118 on: November 01, 2008, 01:41:58 PM »
..............just wondering if I should target a cooler in the 1000 HP range or is it ok to run one bigger than needed (looking for the future)........
I think the advice you are seeking was there in the previous post.
......... i took a wild azz guess and got lucky on this one i put 2 1000hp intercoolers on my liner... kinda right in line with panics formula  :-D
kent
The only thing to think about though is, are you going to make more HP than Kent is?
c ya,
Re: Turbo plenum
« Reply #119 on: November 01, 2008, 02:46:33 PM »
Quote from: Jonny Hotnuts on Today at 11:40:01 AM
I see info about running a bigger compressor but not bigger intercooler.
c ya,
Sum, come on!!!!
Suzuki Vs. Kawa?
No contest!
(joke Kent)
I dont know how much HP KR is making but I am building the motor for 6ish.
-JH
*Andres Segovia
