Author Topic: Scooter builders - piston info?  (Read 2915 times)
« on: September 05, 2008, 12:09:23 AM »
I'm looking for a source for 72 millimeter pistons.  I suspect there are bikes with slugs this size, and as I need to order custom rods anyway, I'm thinking I can shave a few bucks off of my engine build by using an over-the-counter piston and having the rods bored to fit.
Until I sort out the height of the piston, less any machining I might have to do to the face, I'm at an impass.  I'm looking for a reference that would include all the dimensions of the pistons, and at that point, I can then calculate my rod length (stop laughing) and if, or how much, I'll have to shave the deck.  Manufacturer is unimportant, but I suspect Kawasaki, Honda and Suzuki make bikes with bores about this size.
Any help would be appreciated.
Thanks!
Chris
Offline racefanwfo
  • jenks worlds fastest pitbull
Re: Scooter builders - piston info?
« Reply #1 on: September 05, 2008, 02:57:44 AM »
try giving wiseco performance a call.
The speed that you wish to achieve is only limited by the depth of your wallet.
McRat
Offline MattS
    • http://www.wheeltramps.com
« Reply #3 on: September 05, 2008, 12:23:13 PM »
Honda VFR 800 uses them. Actually a 782cc engine.
72mm x 48mm stroke
Matt
« Reply #4 on: September 06, 2008, 11:01:25 AM »
When I need an odd size piston for a scooter i go to
http://www.serco.com.au/browser.htm
And look through the catalouge it has piston diameter and wrist pin sizes for wiseco stuff
Alright so it's in Aaustralia, but so am I
Graham
Offline RidgeRunner
« Reply #5 on: September 12, 2008, 09:59:31 PM »
Chris,
     PM sent.
              Ed Purinton
